Using GRE/IPSEC tunnel as backup to MPLS
Pete89
Level 2
Level 2
Here is my lab. I want to put this into production, but first I need to get it working
in my lab:
http://www.flickr.com/photos/31154535@N07/9195902948/
What we would like to do:
Use the MPLS cloud as a primary for traffic between the two sites. If the MPLS should fail, taffic should
flow over the IPSEC/GRE tunnel. We would like also to do all this with dynamic routing.
We do BGP peering with our MPLS provider on the 01 routers in each site. When then redistribute those
routes into EIGRP.
The routers called fake FW are just that. I have had a hard time to get ASAs to work properly in GNS3,
so I am just using a router for now.
So the problems:
1.)
On the fake FW in Atlanta (top of drawing). Here is the partial output of show ip eigrp topology:
P 5.5.0.0/16, 1 successors, FD is 297252096
        via 10.3.208.140 (297252096/297249536), FastEthernet0/0.601
        via 10.3.208.131 (25602816/25600256), FastEthernet0/0.601
There are similar entries for the other networks in New Haven. My understanding is the route
with the lower metric should be the chosen one? Is that correct? Looking at the routing table
however I see this:
D       5.5.0.0/16
           [90/297252096] via 10.3.208.140, 00:04:24, FastEthernet0/0.601
That route is poing to the 02 router where the GRE tunnel is.
2.)
I cant ping anything from the fake fws to the opposite site. But I can ping everything
from the 02 routers to the opposite site.
I will stop there since I think that is we need to get those two things fixed before we
can continue.
Thanks!
Thanks for posting all the information. I see the problem.
Selecting the 10.5.0.0/16 subnet again here is the behavior:
While MPLS is up on R01 is learned via BGP:
*> 10.5.0.0/16     10.247.247.5                 500     0 8600 8600 i
When MPLS is down, R01 learns this subnet via EIGRP from R02. I assumed it was via iBGP but there isn't any BGP between R01 and R02. This is in fact a local originated route
> 10.5.0.0/16     10.3.208.140     25628160         32768 ?
If you want this done correctly, you must implement route tagging during redistribution. When you redistribute from BGP into EIGRP on either site, you must tag the route. You must also do the same during OSPF to EIGRP redistribution.
Now, during EIGRP to BGP or during EIGRP to OSPF, you must deny those routes based on the tag.
R01 should never advertise 10.5.0.0/16 as a local subnet as it belongs to HVN.
14 Replies 14
Edison Ortiz
Internal EIGRP routes will be preferred over External EIGRP routes regardless of the metric.
You need to configure your GRE tunnels with a protocol other than EIGRP so redistribution can take place and you can use EIGRP metrics for route preference.
Edison,
Thanks for your input. What I ended up doing was changing (with distance command and ACL) the AD of internally learned routes over the tunnel interfaces to 175. Once I did that I could see the BGP learned routes in the routing tables of the FAKE_FWs.
Do you think this is a viable method? or should I go with using OSPF as you sudggested?
Thanks again
P.
I wanted to update this thread because I have a partially working solution. I have not tried Edison's solution yet becuase I want to rule this one out before I go with his idea.
As I described in the prior entries I am increasing AD on routes learned over the GRE tunnel to 175. That puts the BGP routes in the routing table of the 02 router:
## Before MPLS CLOUD GOES DOWN ##
ATL02#sh ip eigrp vrf QWEST_WWW top
IP-EIGRP Topology Table for AS(1)/ID(108.47.84.6) Routing Table: QWEST_WWW
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
       r - reply Status, s - sia Status
P 5.5.0.0/16, 1 successors, FD is 25602816, tag is 8600
        via 10.3.208.131 (25602816/25600256), FastEthernet1/0.601
        via 172.16.1.1 (297249536/30720), Tunnel1
P 5.0.0.0/16, 1 successors, FD is 30720
        via 10.3.208.129 (30720/28160), FastEthernet1/0.601
P 10.3.0.0/16, 1 successors, FD is 30720
P 10.147.147.0/29, 1 successors, FD is 25602816, tag is 8600
P 10.0.0.0/16, 1 successors, FD is 30720
P 10.1.0.0/16, 1 successors, FD is 25602816, tag is 8600
P 10.5.0.0/16, 1 successors, FD is 25602816, tag is 8600
P 10.3.208.128/25, 1 successors, FD is 28160
        via Connected, FastEthernet1/0.601
P 10.5.208.128/25, 1 successors, FD is 25602816, tag is 8600
        via 172.16.1.1 (297246976/28160), Tunnel1
P 172.16.1.0/24, 1 successors, FD is 297244416
        via Connected, Tunnel1
ATL02#
ATL02#
ATL02#
ATL02#sh ip route vrf QWEST_WWW
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 57.129.165.41 to network 0.0.0.0
     5.0.0.0/16 is subnetted, 2 subnets
D EX    5.5.0.0 [170/25602816] via 10.3.208.131, 00:01:00, FastEthernet1/0.601
D       5.0.0.0 [90/30720] via 10.3.208.129, 00:01:00, FastEthernet1/0.601
     172.16.0.0/24 is subnetted, 1 subnets
C       172.16.1.0 is directly connected, Tunnel1
     57.0.0.0/30 is subnetted, 1 subnets
C       67.129.165.40 is directly connected, FastEthernet0/0
     10.0.0.0/8 is variably subnetted, 7 subnets, 3 masks
D       10.3.0.0/16 [90/30720] via 10.3.208.129, 00:01:02, FastEthernet1/0.601
D EX    10.147.147.0/29
           [170/25602816] via 10.3.208.131, 00:01:02, FastEthernet1/0.601
D       10.0.0.0/16 [90/30720] via 10.3.208.129, 00:01:03, FastEthernet1/0.601
D EX    10.1.0.0/16
           [170/25602816] via 10.3.208.131, 00:01:03, FastEthernet1/0.601
D EX    10.5.0.0/16
C       10.3.208.128/25 is directly connected, FastEthernet1/0.601
D EX    10.5.208.128/25
C    108.47.84.0/24 is directly connected, FastEthernet1/0.602
B*   0.0.0.0/0 [20/0] via 57.165.41, 00:01:25
ATL02
Then I bring down the MPLS cloud and everything fails over to the GRE tunnel after about 2 mins.
# MPLS CLOUD GOES DOWN #
IP-EIGRP Topology Table for AS(1)/ID(208.47.84.6) Routing Table: QWEST_WWW
D       5.5.0.0 [175/297249536] via 172.16.1.1, 00:02:01, Tunnel1
D       5.0.0.0 [90/30720] via 10.3.208.129, 00:02:40, FastEthernet1/0.601
D       10.3.0.0/16 [90/30720] via 10.3.208.129, 00:02:42, FastEthernet1/0.601
D       10.147.147.0/29 [175/297249536] via 172.16.1.1, 00:02:03, Tunnel1
D       10.0.0.0/16 [90/30720] via 10.3.208.129, 00:02:42, FastEthernet1/0.601
D       10.1.0.0/16 [175/297249536] via 172.16.1.1, 00:02:04, Tunnel1
D       10.5.0.0/16 [175/297249536] via 172.16.1.1, 00:02:04, Tunnel1
D       10.5.208.128/25 [175/297246976] via 172.16.1.1, 00:02:04, Tunnel1
C    109.47.84.0/24 is directly connected, FastEthernet1/0.602
B*   0.0.0.0/0 [20/0] via 57.129.165.41, 00:18:29
So failover works as planned. The only problem remaining is when the MPLS cloud comes back. Things dont fail back. The only way I can get the routes back into the routing table is to clear the eigrp neighbors on one of the 02 routers.
# MPLS CLOUD COMES BACK UP #
D       5.5.0.0 [175/297249536] via 172.16.1.1, 00:08:45, Tunnel1
D       5.0.0.0 [90/30720] via 10.3.208.129, 00:09:24, FastEthernet1/0.601
D       10.3.0.0/16 [90/30720] via 10.3.208.129, 00:09:26, FastEthernet1/0.601
D       10.147.147.0/29 [175/297249536] via 172.16.1.1, 00:08:47, Tunnel1
D       10.0.0.0/16 [90/30720] via 10.3.208.129, 00:09:26, FastEthernet1/0.601
D       10.1.0.0/16 [175/297249536] via 172.16.1.1, 00:08:49, Tunnel1
D       10.5.0.0/16 [175/297249536] via 172.16.1.1, 00:08:49, Tunnel1
D       10.5.208.128/25 [175/297246976] via 172.16.1.1, 00:08:49, Tunnel1
B*   0.0.0.0/0 [20/0] via 67.129.165.41, 00:25:13
### After Clear EIGRP Neighbors #######
*Mar  1 00:29:22.355: %DUAL-5-NBRCHANGE: IP-EIGRP(1) 1: Neighbor 172.16.1.1 (Tunnel1) is up: new adjacency
D EX    5.5.0.0 [170/25602816] via 10.3.208.131, 00:00:15, FastEthernet1/0.601
D       5.0.0.0 [90/30720] via 10.3.208.129, 00:00:15, FastEthernet1/0.601
D       10.3.0.0/16 [90/30720] via 10.3.208.129, 00:00:17, FastEthernet1/0.601
           [170/25602816] via 10.3.208.131, 00:00:17, FastEthernet1/0.601
D       10.0.0.0/16 [90/30720] via 10.3.208.129, 00:00:18, FastEthernet1/0.601
D EX    10.1.0.0/16
           [170/25602816] via 10.3.208.131, 00:00:18, FastEthernet1/0.601
D EX    10.5.0.0/16
B*   0.0.0.0/0 [20/0] via 67.129.165.41, 00:28:33
ATL02#
Maybe this is what Edison was trying to warn me about. But I want to rule any small mistake out.
Thanks again!
OK, it's official, this is driving me bonkers. I took Edison's advice and set up OSFP on the GRE routers (02 routers in the diagram) and we are doing redistribution
router eigrp 1
no auto-summary
address-family ipv4 vrf QWEST_WWW
  redistribute ospf 1 vrf QWEST_WWW metric 80 1 255 1 1500
  network 10.3.208.0 0.0.0.255
  no auto-summary
  autonomous-system 1
exit-address-family
router ospf 1 vrf QWEST_WWW
log-adjacency-changes
redistribute eigrp 1 metric 1000 subnets
network 172.16.1.0 0.0.0.255 area 0
The 02 routers routing table and EIGRP topology is exactly the same as the prior post. In fact when the MPLS cloud goes down I get the same results; failover works fine, but fail back does not. I still have to issue the clear ip eigrp vrf QWEST_WWW neighbor command to see the perferred routes in the fake_fws routing table.
Tearing hair out now
Adding updated diagram
http://www.flickr.com/photos/31154535@N07/9216288913/lightbox/
I am adding more information so it might help..
I noticed that if I clear the bgp process after fail back on the 01 routers that updates the routing table with the preferred routes over the 01 routers.
## BGP with MPLS down ##
ATL01#sh ip bgp vpnv4 vrf EL_MPLS
BGP table version is 45, local router ID is 10.3.255.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 65000:2 (default for vrf EL_MPLS)
*> 5.0.0.0/16       10.3.208.129         30720         32768 i
*> 5.5.0.0/16       10.3.208.140      32002816         32768 ?
*> 10.0.0.0/16      10.3.208.129         30720         32768 i
*> 10.1.0.0/16      10.3.208.140      32002816         32768 ?
*> 10.3.0.0/16      10.3.208.129         30720         32768 i
*> 10.3.208.128/25  0.0.0.0                  0         32768 ?
*> 10.5.0.0/16      10.3.208.140      32002816         32768 ?
*> 10.5.208.128/25  10.3.208.140      32002816         32768 ?
*> 10.147.147.0/29  10.3.208.140      32002816         32768 ?
*> 172.16.1.0/24    10.3.208.140      32002816         32768 ?
## BGP with MPLS back up ##
BGP table version is 46, local router ID is 10.3.255.2
*  5.5.0.0/16       10.247.247.5                           0 8600 8600 i
*>                  10.3.208.140      32002816         32768 ?
*  10.1.0.0/16      10.247.247.5                           0 8600 8600 i
*  10.5.0.0/16      10.247.247.5                           0 8600 8600 i
*  10.5.208.128/25  10.247.247.5                           0 8600 8600 ?
*  10.147.147.0/29  10.247.247.5                           0 8600 8600 ?
*  172.16.1.0/24    10.247.247.5                           0 8600 8600 ?
#####  After clearing BGP    ##
ATL01#clear ip bgp *
ATL01#
*Mar  1 00:54:31.027: %BGP-5-ADJCHANGE: neighbor 10.247.247.5 vpn vrf EL_MPLS Down User reset
*Mar  1 00:54:31.027: %BGP-5-ADJCHANGE: neighbor 107.7.79.133 vpn vrf EL_WWW Down User reset
ATL01#
*Mar  1 00:54:32.259: %BGP-5-ADJCHANGE: neighbor 107.7.79.133 vpn vrf EL_WWW Up
*Mar  1 00:54:32.487: %BGP-5-ADJCHANGE: neighbor 10.247.247.5 vpn vrf EL_MPLS Up
BGP table version is 13, local router ID is 10.3.255.2
*> 5.0.0.0/16       10.247.247.5                           0 8600 8600 ?
*> 5.5.0.0/16       10.247.247.5                           0 8600 8600 i
*> 10.0.0.0/16      10.247.247.5                           0 8600 8600 ?
*> 10.1.0.0/16      10.247.247.5                           0 8600 8600 i
*> 10.3.0.0/16      10.247.247.5                           0 8600 8600 ?
r> 10.3.208.128/25  10.247.247.5                           0 8600 8600 ?
*> 10.5.0.0/16      10.247.247.5                           0 8600 8600 i
*> 10.5.208.128/25  10.247.247.5                           0 8600 8600 ?
*> 10.147.147.0/29  10.247.247.5                           0 8600 8600 ?
*> 172.16.1.0/24    10.247.247.5                           0 8600 8600 ?
ATL01#
Does this help??
From simplicity sake, I'm picking a subnet from HVN (10.5.0.0/16).
With MPLS down on R01, the BGP table shows:
Which means is learning this route from R02 via iBGP.
With MPLS up on R01, the BGP table shows:
R01 still uses R02 because the AS_PATH length is shorter.
See
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml
Rule 4
When you reset the BGP table:
The entire algorithm restart but I don't see in the logs the iBGP session being made.
Can you post the BGP table from R01 and R02 after a reset?
If you want R01 to be primary after a failover, I recommend using LOCAL_PREF on incoming prefixes from HVN.
Edison,
Thanks so much for your reply.
I have updated the diagram so it is easier to read:
http://www.flickr.com/photos/31154535@N07/9240815180/lightbox/
  • Our goal is to have normal site to site traffic (HVN <-> ATL) go over the 01 Routers (MPLS) in each site. Right now that is not a problem,
  • If the MPLS could goes down we would like site to site traffic to go over the tunnel. Right now that is not a problem either. When MPLS goes away, traffic starts to move over the 02 Routers and through the tunnel.
  • The remaining problem is when the MPLS becomes available again. Traffic does not switch back to the 01 routers automatically. Clearing BGP on the 01 routers fixes it.
I am adding the information you asked for (I hope this is what you wanted). This is the BGP tables and  routing tables of the 01 and 02 routers in ATL when things are running normally i.e site to site traffic is going over the 01 routers.
################################ ATL 01 Router  ###############################
BGP table version is 19, local router ID is 10.3.255.2
ATL01#sh ip route vrf EL_MPLS
Routing Table: EL_MPLS
Gateway of last resort is not set
B       5.5.0.0 [20/0] via 10.247.247.5, 00:17:38
D       5.0.0.0 [90/30720] via 10.3.208.129, 00:17:38, FastEthernet1/0.601
B       172.16.1.0 [20/0] via 10.247.247.5, 00:17:38
D       10.3.0.0/16 [90/30720] via 10.3.208.129, 00:17:38, FastEthernet1/0.601
C       10.247.247.0/29 is directly connected, FastEthernet0/0.601
D       10.0.0.0/16 [90/30720] via 10.3.208.129, 00:17:40, FastEthernet1/0.601
B       10.1.0.0/16 [20/0] via 10.247.247.5, 00:17:40
B       10.5.0.0/16 [20/0] via 10.247.247.5, 00:17:40
B       10.5.208.128/25 [20/0] via 10.247.247.5, 00:17:41
ATL01#
################################ ATL 02 Router  ###############################
ATL02#sh ip bgp vpnv4 vrf QWEST_WWW
BGP table version is 4, local router ID is 10.3.255.1
Route Distinguisher: 65000:1 (default for vrf QWEST_WWW)
*> 0.0.0.0         57.129.165.41            0             0 7600 i
*> 108.47.84.0      0.0.0.0                  0         32768 i
O E2    5.5.0.0 [110/1000] via 172.16.1.1, 01:15:38, Tunnel1
D       5.0.0.0 [90/30720] via 10.3.208.129, 00:20:10, FastEthernet1/0.601
     10.0.0.0/8 is variably subnetted, 6 subnets, 2 masks
D       10.3.0.0/16 [90/30720] via 10.3.208.129, 00:20:12, FastEthernet1/0.601
D       10.0.0.0/16 [90/30720] via 10.3.208.129, 00:20:12, FastEthernet1/0.601
O E2    10.1.0.0/16 [110/1000] via 172.16.1.1, 01:15:40, Tunnel1
O E2    10.5.0.0/16 [110/1000] via 172.16.1.1, 01:15:41, Tunnel1
O E2    10.5.208.128/25 [110/1000] via 172.16.1.1, 01:15:41, Tunnel1
B*   0.0.0.0/0 [20/0] via 57.129.165.41, 00:27:31
As previously recommended, increase the LOCAL_PREF (default is 100) against prefixes learned from HVN on R01 and it should solve the problem on the fail back.
Still no change.
Traffic stays on the 02 routers until I issue a clear ip bgp * on the 01 Router or clear ip eigrp vrf QWEST_WWW on the 02 Router.
I want to add the config I have for the ISP router just in case there is a problem there.
So this is the router between the 01 routers. I have included the routing table during the different phases of normal, failover and failback. I dont think there is much there but perhaps.
earthlink_rt#sh run | b router
router bgp 8600
no synchronization
bgp router-id 1.1.1.2
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf EL_MPLS
  neighbor 10.147.147.4 remote-as 65000
  neighbor 10.147.147.4 activate
  neighbor 10.147.147.4 as-override
  neighbor 10.247.247.6 remote-as 65000
  neighbor 10.247.247.6 activate
  neighbor 10.247.247.6 as-override
  no synchronization
bgp redistribute-internal
exit-address-family
## Normal operation ####
earthlink_rt#sh ip route vrf EL_MPLS
B       5.5.0.0 [20/30720] via 10.147.147.4, 00:10:21
B       5.0.0.0 [20/25628160] via 10.147.147.4, 00:08:32
B       172.16.1.0 [20/25628160] via 10.147.147.4, 00:08:32
     10.0.0.0/8 is variably subnetted, 8 subnets, 3 masks
B       10.3.0.0/16 [20/25628160] via 10.147.147.4, 00:08:32
C       10.147.147.0/29 is directly connected, FastEthernet2/0.601
B       10.0.0.0/16 [20/25628160] via 10.147.147.4, 00:08:34
B       10.1.0.0/16 [20/30720] via 10.147.147.4, 00:10:23
B       10.5.0.0/16 [20/30720] via 10.147.147.4, 00:10:24
B       10.3.208.128/25 [20/0] via 10.247.247.6, 00:08:31
B       10.5.208.128/25 [20/0] via 10.147.147.4, 00:10:24
## MPLS GOES DOWN ###
## Failback ############
B       5.5.0.0 [20/30720] via 10.147.147.4, 00:00:21
B       5.0.0.0 [20/30720] via 10.247.247.6, 00:00:30
B       172.16.1.0 [20/25628160] via 10.247.247.6, 00:00:30
B       10.3.0.0/16 [20/30720] via 10.247.247.6, 00:00:30
B       10.0.0.0/16 [20/30720] via 10.247.247.6, 00:00:32
B       10.1.0.0/16 [20/30720] via 10.147.147.4, 00:00:23
B       10.5.0.0/16 [20/30720] via 10.147.147.4, 00:00:25
B       10.3.208.128/25 [20/0] via 10.247.247.6, 00:00:33
B       10.5.208.128/25 [20/0] via 10.147.147.4, 00:00:25
Also, here is the config I put on the ATL 01 Router that you asked for. The HVN 01 Router looks the same with different IPs.
router eigrp 1
no auto-summary
redistribute bgp 65000 metric 100 1 255 1 1500
network 10.5.208.0 0.0.0.255
no auto-summary
autonomous-system 1
exit-address-family
router bgp 65000
no synchronization
bgp router-id 10.147.147.4
no auto-summary
neighbor 10.147.147.5 remote-as 8600
neighbor 10.147.147.5 ebgp-multihop 2
neighbor 10.147.147.5 activate
neighbor 10.147.147.5 route-map LOCAL_PREF in
no synchronization
network 5.5.0.0 mask 255.255.0.0
network 10.1.0.0 mask 255.255.0.0
network 10.5.0.0 mask 255.255.0.0
exit-address-family
route-map LOCAL_PREF permit 10
set local-preference 500
And here is the routing table of the FAKE_FW in ATL after failback where you can see that the 02 Routers IP (
10.3.208.140) is still there
ATL_FAKE_FW#sh ip route
Gateway of last resort is 108.47.84.1 to network 0.0.0.0
     5.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
D EX   5.5.0.0/16
           [170/25628160] via 10.3.208.140, 00:12:38, FastEthernet0/0.601
C       5.0.0.0/24 is directly connected, FastEthernet1/0.5
D       5.0.0.0/16 is a summary, 00:12:38, Null0
S       172.16.1.0 [1/0] via 10.3.208.140
D       10.3.0.0/16 is a summary, 00:12:38, Null0
D       10.0.0.0/16 is a summary, 00:12:40, Null0
D EX   10.1.0.0/16
           [170/25628160] via 10.3.208.140, 00:12:40, FastEthernet0/0.601
D EX   10.5.0.0/16
           [170/25628160] via 10.3.208.140, 00:12:39, FastEthernet0/0.601
C       10.0.56.0/24 is directly connected, FastEthernet1/0.702
C       10.3.61.0/24 is directly connected, FastEthernet1/0.99
C       10.3.208.0/24 is directly connected, FastEthernet0/0.601
C   108.47.84.0/24 is directly connected, FastEthernet0/0.602
S*   0.0.0.0/0 [1/0] via 208.47.84.1
Will that local preference attribute get passed down to the FAKE_FW? It is only running EIGRP.
Thanks again for your patience!
Please post the BGP and Routing Table from all 4 routers (ATL01/02 and HVN01/02) during normal, failover and failback conditions.
Please be descriptive with the names. I see now an earthlink router being mentioned and that's not in the diagram.
Here are the tables:
# Normal Operations ##
############# ATL01 ################
ATL01#sh ip int br
Interface                 IP-Address     OK? Method Status
     Protocol
FastEthernet0/0           unassigned     YES NVRAM up                   up
FastEthernet0/0.601       10.247.247.6   YES NVRAM up                   up
FastEthernet0/0.1125       207.7.79.134   YES NVRAM up                   up
FastEthernet1/0           unassigned     YES NVRAM up                   up
FastEthernet1/0.601       10.3.208.131   YES NVRAM up                   up
FastEthernet1/0.602       108.47.84.5     YES NVRAM up                   up
FastEthernet2/0           unassigned     YES NVRAM administratively down down
FastEthernet3/0           unassigned     YES NVRAM administratively down down
Loopback0                 10.3.255.2     YES NVRAM up                   up
ATL01#sh ip bgp vpnv4 all
BGP table version is 25, local router ID is 10.3.255.2
Route Distinguisher: 65000:1 (default for vrf EL_WWW)
*> 0.0.0.0         207.7.79.133             0             0 8600 i
*> 208.47.84.0     0.0.0.0                 0         32768 i
*> 5.5.0.0/16       10.247.247.5                 500     0 8600 8600 i
*> 10.1.0.0/16     10.247.247.5                 500     0 8600 8600 i
*> 10.5.208.128/25 10.247.247.5                 500     0 8600 8600 ?
*> 172.16.1.0/24   10.247.247.5                  500     0 8600 8600 ?
B       5.5.0.0 [20/0] via 10.247.247.5, 00:22:41
D       5.0.0.0 [90/30720] via 10.3.208.129, 00:20:57, FastEthernet1/0.601
B       172.16.1.0 [20/0] via 10.247.247.5, 00:22:41
D       10.3.0.0/16 [90/30720] via 10.3.208.129, 00:20:57, FastEthernet1/0.601
D       10.0.0.0/16 [90/30720] via 10.3.208.129, 00:20:59, FastEthernet1/0.601
B       10.1.0.0/16 [20/0] via 10.247.247.5, 00:22:43
B       10.5.0.0/16 [20/0] via 10.247.247.5, 00:22:43
################# ATL02 ################################
ATL02#sh ip int br
     Protocol
FastEthernet0/0           57.129.165.42   YES NVRAM up                  up
FastEthernet1/0.601       10.3.208.140   YES NVRAM up                   up
FastEthernet1/0.602       108.47.84.6     YES NVRAM up                   up
Loopback0                10.3.255.1     YES NVRAM up                   up
Tunnel1                   172.16.1.2     YES NVRAM up                   up
ATL02#sh ip bgp vpnv4 vrf all
%Unknown VRF
ATL02#sh ip bgp vpnv4 all
O E2   5.5.0.0 [110/1000] via 172.16.1.1, 05:26:37, Tunnel1
D       5.0.0.0 [90/30720] via 10.3.208.129, 00:23:35, FastEthernet1/0.601
D      10.3.0.0/16 [90/30720] via 10.3.208.129, 00:23:37, FastEthernet1/0.601
D       10.0.0.0/16 [90/30720] via 10.3.208.129, 00:23:37, FastEthernet1/0.601
O E2   10.1.0.0/16 [110/1000] via 172.16.1.1, 05:26:39, Tunnel1
O E2   10.5.0.0/16 [110/1000] via 172.16.1.1, 05:26:39, Tunnel1
O E2   10.5.208.128/25 [110/1000] via 172.16.1.1, 05:26:39, Tunnel1
B*   0.0.0.0/0 [20/0] via 67.129.165.41, 04:38:29
B       10.5.208.128/25 [20/0] via 10.247.247.5, 00:22:45
##################### ATL FAKE_FW ####################################
ATL_FAKE_FW#sh ip int br
     Protocol
FastEthernet0/0.601       10.3.208.129   YES NVRAM up                   up
FastEthernet0/0.602       108.47.84.10   YES NVRAM up                   up
FastEthernet1/0.5         5.0.0.1         YES NVRAM up                   up
FastEthernet1/0.99         10.3.61.1       YES NVRAM up                   up
FastEthernet1/0.702       10.0.56.1       YES NVRAM up                   up
Loopback0                 unassigned     YES NVRAM up                   up
ATL_FAKE_FW#sh ip eigrp topology
IP-EIGRP Topology Table for AS(1)/ID(10.3.208.129)
P 5.0.0.0/16, 1 successors, FD is 28160
       via Summary (28160/0), Null0
P 5.0.0.0/24, 1 successors, FD is 28160
       via Connected, FastEthernet1/0.5
P 10.3.0.0/16, 1 successors, FD is 28160
P 10.0.0.0/16, 1 successors, FD is 28160
P 10.0.56.0/24, 1 successors, FD is 28160
       via Connected, FastEthernet1/0.702
P 172.16.1.0/24, 0 successors, FD is Inaccessible
       via 10.3.208.140 (25628160/25625600), FastEthernet0/0.601
P 10.3.208.0/24, 1 successors, FD is 28160
       via Connected, FastEthernet0/0.601
D EX   5.5.0.0/16
           [170/25602816] via 10.3.208.131, 00:25:13, FastEthernet0/0.601
D       5.0.0.0/16 is a summary, 00:26:57, Null0
D       10.3.0.0/16 is a summary, 00:26:57, Null0
D       10.0.0.0/16 is a summary, 00:26:59, Null0
D EX   10.1.0.0/16
           [170/25602816] via 10.3.208.131, 00:25:15, FastEthernet0/0.601
D EX   10.5.0.0/16
           [170/25602816] via 10.3.208.131, 00:25:16, FastEthernet0/0.601
########################### ISP1 (MPLS Provider) ####################
earthlink_rt#sh ip int br
     Protocol
FastEthernet0/0.601       10.247.247.5   YES NVRAM up                   up
FastEthernet0/0.1125      207.7.79.133   YES NVRAM up                   up
FastEthernet1/0.10         166.166.166.1   YES NVRAM up                   up
FastEthernet2/0           unassigned      YES NVRAM up                   up
FastEthernet2/0.44         109.113.252.34 YES NVRAM up                   up
FastEthernet2/0.601       10.147.147.5   YES NVRAM up                   up
Loopback1                 1.1.1.2         YES NVRAM up                   up
earthlink_rt#sh ip bgp vpnv4 all
BGP table version is 69, local router ID is 1.1.1.2
Route Distinguisher: 8600:1 (default for vrf EL_WWW)
r> 0.0.0.0         166.166.166.3                          0 9600 7600 65000 i
* 73.144.247.0/24 109.113.252.33           0             0 65000
65000 65000 65000 65000 65000 i
*>                 166.166.166.3                         0 9600 7600 65000 i
* 108.47.84.0     207.7.79.134             0             0 65000
Route Distinguisher: 8600:2 (default for vrf EL_MPLS)
*> 5.0.0.0/16       10.247.247.6         30720             0 65000 i
*> 5.5.0.0/16       10.147.147.4         30720             0 65000 i
*> 10.0.0.0/16     10.247.247.6         30720             0 65000 i
*> 10.1.0.0/16     10.147.147.4         30720             0 65000 i
*> 10.3.0.0/16     10.247.247.6         30720             0 65000 i
*> 10.3.208.128/25 10.247.247.6             0             0 65000 ?
*                   10.147.147.4     25628160             0 65000 ?
*> 10.5.0.0/16     10.147.147.4         30720            0 65000 i
*> 10.5.208.128/25 10.147.147.4             0             0 65000 ?
*> 172.16.1.0/24   10.147.147.4     25628160             0 65000 ?
B       5.5.0.0 [20/30720] via 10.147.147.4, 00:59:35
B       5.0.0.0 [20/30720] via 10.247.247.6, 00:31:41
B       172.16.1.0 [20/25628160] via 10.147.147.4, 00:33:25
B       10.3.0.0/16 [20/30720] via 10.247.247.6, 00:31:41
B       10.0.0.0/16 [20/30720] via 10.247.247.6, 00:31:43
B       10.1.0.0/16 [20/30720] via 10.147.147.4, 00:59:37
B       10.5.0.0/16 [20/30720] via 10.147.147.4, 00:59:39
B       10.3.208.128/25 [20/0] via 10.247.247.6, 00:33:24
B       10.5.208.128/25 [20/0] via 10.147.147.4, 00:59:39
#################### HVN 01 #####################################
HVN1_01#sh ip int br
     Protocol
FastEthernet0/0.44         109.113.252.33 YES NVRAM up                   up
FastEthernet0/0.601       10.147.147.4   YES NVRAM up                   up
FastEthernet1/0.601       10.5.208.131   YES NVRAM up                   up
FastEthernet1/0.602       73.144.247.5   YES NVRAM up                   up
HVN1_01#sh ip bgp vpnv4 all
BGP table version is 99, local router ID is 10.147.147.4
Route Distinguisher: 65000:1 (default for vrf EL_MPLS)
*> 5.0.0.0/16       10.147.147.5                 500     0 8600 8600 i
*> 5.5.0.0/16       10.5.208.129         30720         32768 i
*> 10.0.0.0/16     10.147.147.5                 500     0 8600 8600 i
*> 10.1.0.0/16     10.5.208.129         30720         32768 i
*> 10.3.0.0/16     10.147.147.5                 500     0 8600 8600 i
* 10.3.208.128/25 10.147.147.5                500     0 8600 8600 ?
*>                 10.5.208.140     25628160         32768 ?
*> 10.5.0.0/16     10.5.208.129         30720         32768 i
*> 10.5.208.128/25 0.0.0.0                 0         32768 ?
*> 172.16.1.0/24   10.5.208.140     25628160         32768 ?
Route Distinguisher: 65000:2 (default for vrf EL_WWW)
*> 0.0.0.0         109.113.252.34           0             0 8600 i
*> 73.144.247.0/24 0.0.0.0                 0         32768 i
HVN1_01#sh ip route vrf EL_MPLS
D       5.5.0.0 [90/30720] via 10.5.208.129, 01:49:53, FastEthernet1/0.601
B       5.0.0.0 [20/0] via 10.147.147.5, 00:35:48
D EX   172.16.1.0
           [170/25628160] via 10.5.208.140, 01:49:52, FastEthernet1/0.601
B       10.3.0.0/16 [20/0] via 10.147.147.5, 00:35:48
C       10.147.147.0/29 is directly connected, FastEthernet0/0.601
B       10.0.0.0/16 [20/0] via 10.147.147.5, 00:35:50
D       10.1.0.0/16 [90/30720] via 10.5.208.129, 01:49:54, FastEthernet1/0.601
D       10.5.0.0/16 [90/30720] via 10.5.208.129, 01:49:55, FastEthernet1/0.601
D EX   10.3.208.128/25
          [170/25628160] via 10.5.208.140, 01:49:55, FastEthernet1/0.601
C       10.5.208.128/25 is directly connected, FastEthernet1/0.601
##################### HVN02 ##################################
HVN02#sh ip int br
     Protocol
FastEthernet0/0           65.124.198.174 YES NVRAM up                   up
FastEthernet1/0.601       10.5.208.140   YES NVRAM up                   up
FastEthernet1/0.602       73.144.247.6   YES NVRAM up                   up
FastEthernet3/0           unassigned     YES NVRAM up                  up
Loopback0                 10.5.255.1     YES NVRAM up                   up
Tunnel1                   172.16.1.1     YES NVRAM up                   up
HVN02#sh ip bgp vpnv4 all
BGP table version is 4, local router ID is 10.5.255.1
*> 0.0.0.0         65.124.198.173           0             0 7600 i
HVN02#sh ip route vrf QWEST_WWW
Gateway of last resort is 65.124.198.173 to network 0.0.0.0
     65.0.0.0/30 is subnetted, 1 subnets
C       65.124.198.172 is directly connected, FastEthernet0/0
D       5.5.0.0 [90/30720] via 10.5.208.129, 01:53:24, FastEthernet1/0.601
O E2   5.0.0.0 [110/1000] via 172.16.1.2, 00:39:14, Tunnel1
O E2   10.3.0.0/16 [110/1000] via 172.16.1.2, 00:39:16, Tunnel1
O E2   10.0.0.0/16 [110/1000] via 172.16.1.2, 00:39:16, Tunnel1
D       10.1.0.0/16 [90/30720] via 10.5.208.129, 01:53:26, FastEthernet1/0.601
D       10.5.0.0/16 [90/30720] via 10.5.208.129, 01:53:26, FastEthernet1/0.601
O E2   10.3.208.128/25 [110/1000] via 172.16.1.2, 04:54:04, Tunnel1
     73.0.0.0/24 is subnetted, 1 subnets
C       63.144.247.0 is directly connected, FastEthernet1/0.602
B*   0.0.0.0/0 [20/0] via 65.124.198.173, 05:42:50
####################### HVN FAKE_FW ####################################
fake_fw_hvn#sh ip int br
     Protocol
FastEthernet0/0.601       10.5.208.129   YES NVRAM up                   up
FastEthernet0/0.602       73.144.247.10   YES NVRAM up                   up
FastEthernet1/0.5         5.5.5.1         YES NVRAM up                   up
FastEthernet1/0.99         10.5.61.1       YES NVRAM up                   up
FastEthernet1/0.702       10.1.51.1       YES NVRAM up                   up
fake_fw_hvn#sh ip eigrp topology
IP-EIGRP Topology Table for AS(1)/ID(10.5.208.129)
P 5.5.0.0/16, 1 successors, FD is 28160
P 5.0.0.0/16, 1 successors, FD is 25602816, tag is 8600
       via 10.5.208.131 (25602816/25600256), FastEthernet0/0.601
P 5.5.5.0/24, 1 successors, FD is 28160
P 10.3.0.0/16, 1 successors, FD is 25602816, tag is 8600
P 10.0.0.0/16, 1 successors, FD is 25602816, tag is 8600
P 10.1.0.0/16, 1 successors, FD is 28160
P 10.5.0.0/16, 1 successors, FD is 28160
P 10.5.61.0/24, 1 successors, FD is 28160
       via Connected, FastEthernet1/0.99
P 10.1.51.0/24, 1 successors, FD is 28160
P 10.3.208.128/25, 1 successors, FD is 25628160
       via 10.5.208.140 (25628160/25625600), FastEthernet0/0.601, serno 72
P 10.5.208.128/25, 1 successors, FD is 28160
       via 10.5.208.140 (25628160/25625600), FastEthernet0/0.601, serno 90
fake_fw_hvn#sh ip route
Gateway of last resort is 73.144.247.1 to network 0.0.0.0
D       5.5.0.0/16 is a summary, 01:57:53, Null0
C       5.5.5.0/24 is directly connected, FastEthernet1/0.5
D EX   5.0.0.0/16
           [170/25602816] via 10.5.208.131, 00:43:43, FastEthernet0/0.601
S       172.16.1.0 [1/0] via 10.5.208.140
D EX   10.3.0.0/16
D EX   10.0.0.0/16
           [170/25602816] via 10.5.208.131, 00:43:45, FastEthernet0/0.601
D       10.1.0.0/16 is a summary, 01:57:55, Null0
D       10.5.0.0/16 is a summary, 01:57:56, Null0
C       10.5.61.0/24 is directly connected, FastEthernet1/0.99
C       10.1.51.0/24 is directly connected, FastEthernet1/0.702
           [170/25628160] via 10.5.208.140, 01:57:56, FastEthernet0/0.601
C       10.5.208.128/25 is directly connected, FastEthernet0/0.601
C       73.144.247.0 is directly connected, FastEthernet0/0.602
S*   0.0.0.0/0 [1/0] via 63.144.247.1
############################# ATL01 #############################
BGP table version is 41, local router ID is 10.3.255.2
*> 5.5.0.0/16       10.3.208.140     25628160         32768 ?
*> 10.1.0.0/16     10.3.208.140     25628160         32768 ?
*> 10.5.0.0/16     10.3.208.140     25628160         32768 ?
*> 10.5.208.128/25 10.3.208.140     25628160         32768 ?
*> 172.16.1.0/24   10.3.208.140    25628160         32768 ?
D EX   5.5.0.0 [170/25628160] via 10.3.208.140, 00:01:10, FastEthernet1/0.601
D       5.0.0.0 [90/30720] via 10.3.208.129, 00:49:29, FastEthernet1/0.601
D EX   172.16.1.0
D       10.3.0.0/16 [90/30720] via 10.3.208.129, 00:49:29, FastEthernet1/0.601
D       10.0.0.0/16 [90/30720] via 10.3.208.129, 00:49:31, FastEthernet1/0.601
D EX   10.1.0.0/16
           [170/25628160] via 10.3.208.140, 00:01:12, FastEthernet1/0.601
D EX   10.5.0.0/16
           [170/25628160] via 10.3.208.140, 00:01:13, FastEthernet1/0.601
################# ATL02 #################################
Gateway of last resort is 67.129.165.41 to network 0.0.0.0
O E2   5.5.0.0 [110/1000] via 172.16.1.1, 05:54:33, Tunnel1
D       5.0.0.0 [90/30720] via 10.3.208.129, 00:51:31, FastEthernet1/0.601
C       57.129.165.40 is directly connected, FastEthernet0/0
D       10.3.0.0/16 [90/30720] via 10.3.208.129, 00:51:33, FastEthernet1/0.601
D      10.0.0.0/16 [90/30720] via 10.3.208.129, 00:51:33, FastEthernet1/0.601
O E2   10.1.0.0/16 [110/1000] via 172.16.1.1, 05:54:35, Tunnel1
O E2   10.5.0.0/16 [110/1000] via 172.16.1.1, 05:54:36, Tunnel1
O E2   10.5.208.128/25 [110/1000] via 172.16.1.1, 05:54:36, Tunnel1
B*   0.0.0.0/0 [20/0] via 67.129.165.41, 05:06:26
###################### ATL FAKE_FW #############################
P 5.5.0.0/16, 1 successors, FD is 25628160
P 10.1.0.0/16, 1 successors, FD is 25628160
P 10.5.0.0/16, 1 successors, FD is 25628160
P 10.5.208.128/25, 1 successors, FD is 25628160
D EX   5.5.0.0/16
           [170/25628160] via 10.3.208.140, 00:06:05, FastEthernet0/0.601
D       5.0.0.0/16 is a summary, 00:56:06, Null0
D      10.3.0.0/16 is a summary, 00:56:06, Null0
D       10.0.0.0/16 is a summary, 00:56:08, Null0
D EX   10.1.0.0/16
           [170/25628160] via 10.3.208.140, 00:06:07, FastEthernet0/0.601
D EX   10.5.0.0/16
################## ISP01 (MPLS Provider) ##################
######################### HVN01 ############################
BGP table version is 109, local router ID is 10.147.147.4
*> 5.0.0.0/16       10.5.208.140     25628160         32768 ?
*> 10.0.0.0/16     10.5.208.140     25628160         32768 ?
*> 10.3.0.0/16     10.5.208.140     25628160         32768 ?
*> 10.3.208.128/25 10.5.208.140     25628160         32768 ?
D       5.5.0.0 [90/30720] via 10.5.208.129, 02:12:56, FastEthernet1/0.601
D EX   5.0.0.0 [170/25628160] via 10.5.208.140, 00:13:09, FastEthernet1/0.601
D EX   172.16.1.0
           [170/25628160] via 10.5.208.140, 02:12:55, FastEthernet1/0.601
D EX   10.3.0.0/16
D EX   10.0.0.0/16
           [170/25628160] via 10.5.208.140, 00:13:11, FastEthernet1/0.601
D       10.1.0.0/16 [90/30720] via 10.5.208.129, 02:12:58, FastEthernet1/0.601
D       10.5.0.0/16 [90/30720] via 10.5.208.129, 02:12:58, FastEthernet1/0.601
           [170/25628160] via 10.5.208.140, 02:12:57, FastEthernet1/0.601
##################### HVN02 #############################3
D       5.5.0.0 [90/30720] via 10.5.208.129, 02:14:52, FastEthernet1/0.601
O E2   5.0.0.0 [110/1000] via 172.16.1.2, 01:00:43, Tunnel1
O E2   10.3.0.0/16 [110/1000] via 172.16.1.2, 01:00:45, Tunnel1
O E2   10.0.0.0/16 [110/1000] via 172.16.1.2, 01:00:45, Tunnel1
D       10.1.0.0/16 [90/30720] via 10.5.208.129, 02:14:54, FastEthernet1/0.601
D       10.5.0.0/16 [90/30720] via 10.5.208.129, 02:14:56, FastEthernet1/0.601
O E2   10.3.208.128/25 [110/1000] via 172.16.1.2, 05:15:34, Tunnel1
C       73.144.247.0 is directly connected, FastEthernet1/0.602
B*   0.0.0.0/0 [20/0] via 65.124.198.173, 06:04:20
################# HVN FAKE FW ##############################
P 5.0.0.0/16, 1 successors, FD is 25628160
P 10.3.0.0/16, 1 successors, FD is 25628160
P 10.0.0.0/16, 1 successors, FD is 25628160
D       5.5.0.0/16 is a summary, 02:17:25, Null0
D EX   5.0.0.0/16
           [170/25628160] via 10.5.208.140, 00:17:39, FastEthernet0/0.601
D EX   10.3.0.0/16
D EX   10.0.0.0/16
           [170/25628160] via 10.5.208.140, 00:17:41, FastEthernet0/0.601
D       10.1.0.0/16 is a summary, 02:17:27, Null0
D       10.5.0.0/16 is a summary, 02:17:28, Null0
           [170/25628160] via 10.5.208.140, 02:17:28, FastEthernet0/0.601
S*   0.0.0.0/0 [1/0] via 73.144.247.1
#### MPLS COMES BACK UP ###
BGP table version is 42, local router ID is 10.3.255.2
* 5.5.0.0/16       10.247.247.5                 500     0 8600 8600 i
*>                 10.3.208.140     25628160         32768 ?
* 10.1.0.0/16     10.247.247.5                 500     0 8600 8600 i
* 10.5.0.0/16     10.247.247.5                 500     0 8600 8600 i
* 10.5.208.128/25 10.247.247.5                 500     0 8600 8600 ?
ATL01# sh ip route vrf EL_MPLS
D EX   5.5.0.0 [170/25628160] via 10.3.208.140, 00:21:19, FastEthernet1/0.601
D       5.0.0.0 [90/30720] via 10.3.208.129, 01:09:37, FastEthernet1/0.601
D EX   172.16.1.0
D       10.3.0.0/16 [90/30720] via 10.3.208.129, 01:09:37, FastEthernet1/0.601
D       10.0.0.0/16 [90/30720] via 10.3.208.129, 01:09:39, FastEthernet1/0.601
D EX   10.1.0.0/16
           [170/25628160] via 10.3.208.140, 00:21:21, FastEthernet1/0.601
D EX   10.5.0.0/16
################### ATL02 ################################
sh ip bgp vpnv4 all
*> 0.0.0.0         67.129.165.41           0             0 7600 i
O E2   5.5.0.0 [110/1000] via 172.16.1.1, 06:18:21, Tunnel1
D       5.0.0.0 [90/30720] via 10.3.208.129, 01:15:19, FastEthernet1/0.601
     67.0.0.0/30 is subnetted, 1 subnets
D      10.3.0.0/16 [90/30720] via 10.3.208.129, 01:15:21, FastEthernet1/0.601
D       10.0.0.0/16 [90/30720] via 10.3.208.129, 01:15:21, FastEthernet1/0.601
O E2   10.1.0.0/16 [110/1000] via 172.16.1.1, 06:18:23, Tunnel1
O E2   10.5.0.0/16 [110/1000] via 172.16.1.1, 06:18:23, Tunnel1
O E2   10.5.208.128/25 [110/1000] via 172.16.1.1, 06:18:23, Tunnel1
B*   0.0.0.0/0 [20/0] via 67.129.165.41, 05:30:13
###################### ATL FAKE_FW #################################
D EX  5.5.0.0/16
           [170/25628160] via 10.3.208.140, 00:29:22, FastEthernet0/0.601
D       5.0.0.0/16 is a summary, 01:19:24, Null0
D       10.3.0.0/16 is a summary, 01:19:24, Null0
D       10.0.0.0/16 is a summary, 01:19:26, Null0
D EX   10.1.0.0/16
           [170/25628160] via 10.3.208.140, 00:29:24, FastEthernet0/0.601
D EX   10.5.0.0/16
           [170/25628160] via 10.3.208.140, 00:29:27, FastEthernet0/0.601
S*   0.0.0.0/0 [1/0] via 108.47.84.1
####################### ISP01 (MPLS Provider) ##################
BGP table version is 106, local router ID is 1.1.1.2
* 5.0.0.0/16       10.147.147.4     25628160             0 65000 ?
*>                 10.247.247.6         30720             0 65000 i
*                   10.247.247.6     25628160             0 65000 ?
* 10.0.0.0/16     10.147.147.4     25628160             0 65000 ?
* 10.3.0.0/16     10.147.147.4     25628160             0 65000 ?
* 10.3.208.128/25 10.147.147.4     25628160             0 65000 ?
*>                 10.247.247.6             0             0 65000 ?
* 172.16.1.0/24   10.147.147.4     25628160             0 65000 ?
*>                 10.247.247.6     25628160             0 65000 ?
B       5.5.0.0 [20/30720] via 10.147.147.4, 00:17:04
B       5.0.0.0 [20/30720] via 10.247.247.6, 00:17:29
B       172.16.1.0 [20/25628160] via 10.247.247.6, 00:17:29
B       10.3.0.0/16 [20/30720] via 10.247.247.6, 00:17:29
B       10.0.0.0/16 [20/30720] via 10.247.247.6, 00:17:31
B       10.1.0.0/16 [20/30720] via 10.147.147.4, 00:17:06
B      10.5.0.0/16 [20/30720] via 10.147.147.4, 00:17:06
B       10.3.208.128/25 [20/0] via 10.247.247.6, 00:17:31
B       10.5.208.128/25 [20/0] via 10.147.147.4, 00:17:06
BGP table version is 110, local router ID is 10.147.147.4
* 5.0.0.0/16       10.147.147.5                 500     0 8600 8600 i
* 10.0.0.0/16     10.147.147.5                 500     0 8600 8600 i
* 10.3.0.0/16     10.147.147.5                 500     0 8600 8600 i
* 172.16.1.0/24   10.147.147.5                 500     0 8600 8600 ?
D       5.5.0.0 [90/30720] via 10.5.208.129, 02:39:35, FastEthernet1/0.601
D EX   5.0.0.0 [170/25628160] via 10.5.208.140, 00:39:49, FastEthernet1/0.601
D EX   172.16.1.0
           [170/25628160] via 10.5.208.140, 02:39:35, FastEthernet1/0.601
D EX   10.3.0.0/16
D EX   10.0.0.0/16
           [170/25628160] via 10.5.208.140, 00:39:51, FastEthernet1/0.601
D       10.1.0.0/16 [90/30720] via 10.5.208.129, 02:39:37, FastEthernet1/0.601
D       10.5.0.0/16 [90/30720] via 10.5.208.129, 02:39:37, FastEthernet1/0.601
           [170/25628160] via 10.5.208.140, 02:39:37, FastEthernet1/0.601
########################## HVN02 ###########################
D       5.5.0.0 [90/30720] via 10.5.208.129, 02:41:38, FastEthernet1/0.601
O E2   5.0.0.0 [110/1000] via 172.16.1.2, 01:27:29, Tunnel1
O E2   10.3.0.0/16 [110/1000] via 172.16.1.2, 01:27:31, Tunnel1
O E2   10.0.0.0/16 [110/1000] via 172.16.1.2, 01:27:31, Tunnel1
D       10.1.0.0/16 [90/30720] via 10.5.208.129, 02:41:40, FastEthernet1/0.601
D       10.5.0.0/16 [90/30720] via 10.5.208.129, 02:41:40, FastEthernet1/0.601
O E2   10.3.208.128/25 [110/1000] via 172.16.1.2, 05:42:18, Tunnel1
B*   0.0.0.0/0 [20/0] via 65.124.198.173, 06:31:04
####################### HVN fake_fw ####################
D       5.5.0.0/16 is a summary, 02:43:31, Null0
D EX   5.0.0.0/16
           [170/25628160] via 10.5.208.140, 00:43:44, FastEthernet0/0.601
D EX   10.3.0.0/16
D EX   10.0.0.0/16
           [170/25628160] via 10.5.208.140, 00:43:46, FastEthernet0/0.601
D       10.1.0.0/16 is a summary, 02:43:33, Null0
D       10.5.0.0/16 is a summary, 02:43:33, Null0
           [170/25628160] via 10.5.208.140, 02:43:33, FastEthernet0/0.601
Edison,
That did the trick I applied tags on the routes and failback started working just fine.
Thank you so much for you help and patience on this. I am a newbie to routing protocols in general and this was a tall order for my first stab at it.
I will publish the entire solution after I do some cleanup of the configs. That will also give people the chance to see if we have any unnessary or potencially dangerous commands.
Again, thank you!!!
Adding the configs of all the routers except ISP02 (www provider)
Please keep in mind this was all done in GNS3 0.8.4 and we wish to deploy in production after we hit it with a hammer a little longer. If anyone sees something they think is wrong please let me know.
Excellent and thanks for the post. One additional ask from me is to mark this thread as resolved.
Best of luck on the real network deployment and don't hesitate to post back if you run into issues.
Edison.
