Bookmark
Subscribe
1095
Traceroute behavior within MPLS Domain
wood20011
From the LAN side of my CE (Customer Edge) router, I am able to ping and traceroute across my MPLS network to the other CE router on the LAN side.
My VRF (METERING) is supposed to traverse an MPLS-TE tunnel (unidirectional) to the P router. As this is unidirectional, I have also established a MPLS-TE tunnel in the opposite direction from the P router back towards my PE router.
My question is:- when I perform a traceroute, I see all the intermediate hops from the LAN side of the CE to far end of the other CE (LAN side).
The fact that I am traversing the MPLS-TE tunnel and the MPLS network, shouldn't the intermediate hops (MPLS routers) be transparent to the customer's traceroute ?
Similar to the traceroute results when implementing DMVPN IPSEC.
The following is an extract of my PE router:-
NB:- ip cef distributed has been enabled.
CISCO_MPLS_RTR#show run
Building configuration...
Current configuration : 4248 bytes
version 15.5
no platform punt-keepalive disable-kernel-core
hostname CISCO_MPLS_RTR
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
no aaa new-model
ip vrf METERING
description VRF_METERING
rd 24316:6100
route-target export 24316:6001
route-target import 24316:6001
bgp next-hop Loopback0 -------------------map vrf METERING to loopback 0
subscriber templating
mpls label protocol ldp
mpls traffic-eng tunnels
license udi pid ISR4351/K9 sn FDO22302P0W
license boot level appxk9
redundancy
mode none
vlan internal allocation policy ascending
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip router isis 1
interface Tunnel1
ip unnumbered Loopback0
mpls ip
tunnel mode mpls traffic-eng
tunnel destination 10.64.X.XX -------------------------------to P router 1
tunnel mpls traffic-eng autoroute announce
tunnel mpls traffic-eng forwarding-adjacency
tunnel mpls traffic-eng priority 7 7
tunnel mpls traffic-eng bandwidth 100
tunnel mpls traffic-eng path-option 1 dynamic
tunnel mpls traffic-eng record-route
isis metric 10
interface Tunnel2
mpls ip
tunnel destination 10.64.X.XXX---------------------------to P router 2
isis metric 10
interface GigabitEthernet0/0/0
ip address 192.168.243.1 255.255.255.252----------------to next PE router within MPLS domain
ip router isis 1
ip policy route-map TEST
media-type rj45
negotiation auto
mpls ip
ip rsvp bandwidth
interface GigabitEthernet0/0/2
no ip address
negotiation auto
interface GigabitEthernet0/0/2.5-------------------------to CE router (Cisco CGS2520)
encapsulation dot1Q 50
ip vrf forwarding METERING
ip address 172.172.10.1 255.255.255.252
interface Vlan1
no ip address
shutdown
router isis 1
net 49.0007.0100.6400.9999.00
metric-style wide
log-adjacency-changes
mpls traffic-eng router-id Loopback0
mpls traffic-eng level-2
router bgp 24316
bgp router-id 1.1.1.1
bgp log-neighbor-changes
neighbor 10.64.X.XX remote-as 24316--------------------to PE router 1
neighbor 10.64.X.XX update-source Loopback0
neighbor 10.64.X.XXX remote-as 24316------------------to PE router 2
neighbor 10.64.X.XXX update-source Loopback0
address-family ipv4
neighbor 10.64.X.XX activate
neighbor 10.64.X.XXX activate
exit-address-family
address-family vpnv4
neighbor 10.64.X.XX send-community extended
neighbor 10.64.X.XXX send-community extended
exit-address-family
address-family ipv4 vrf METERING
neighbor 172.172.10.2 remote-as 1234 ----------------to CE router using BGP
neighbor 172.172.10.2 activate
neighbor 172.172.10.2 default-originate
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 1.1.1.1 255.255.255.255 Tunnel1--------------------map loopback 0 to tunnel 1
access-list 1 permit 172.172.10.0 0.0.0.255----------tried this command as above config would not work.
route-map TEST permit 10
match ip address 1
set interface Tunnel1
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
end
Michael
Hi Julian
I tried the command "no mpls ip propagate-ttl" and it worked as descibed.
No more intermediary steps.
Thankyou for your assistance.
Michael
julian.bendix
Level 7
Level 7
Hi!
The fact that you (or the Customer) are seeing the Routers within the MPLS cloud is actually the default behavior.
So until now everything seems working as designed.
I think what you want to do is exactly this:
https://www.cisco.com/c/en/us/support/docs/multiprotocol-label-switching-mpls/mpls/26585-mpls-traceroute.html#no_mpls
By adding the "#no mpls ip propagate-ttl" command you would suppress the MPLS Routers from the Traceroutes comming from outside of the MPLS Cloud.
Take the time to read through the section describing this command in the linke above :)
Is that solving your case?
Best regards
Julian
Hi Julian
Michael
Hi!
Glad to hear! :)
Best regards
Julian
P.S. please always mark helpful replies or other replies from other users as solution if applicable
