traceroute break
korbenda11as
For sure this is an easy question. How to stop traceroute before it reaches line 30? also what are the shortcut keys for cli? thanks.
10 Replies 10
royalblues
Level 10
Level 10
USe the break sequence cntl+shft+6 (all together) then x
Narayan
Hi Narayan,
Even i have experianced the same.if continous ping has given it had stopped with --->cntl+shft+6 (all together) then x ,
but in the case of traceroute .....many times we have to wait till the 30th hop
ujil
For me it works always.. Actually you dont even need to press x after the combined sequence
MS_IP_L3#traceroute 7.2.2.2
Tracing the route to 7.2.2.2
1 *
MS_IP_L3#
Narayan
Hi Narayan,
Thanks for the reply ...
ujil
thanks a million!
cyptic
Hi!
This is the strange way of doing it.
hold: ctrl+shift+6
release and press x.
x is not necessary, sometimes even not good to use (while connected to from one router another router via a Telnet session and running traceroute there, it would just return to the first router session).
But ctrl+shift+6
pressed several times might help.
BR,
Milan
Thanks a million!
In my experience the X is not needed and as Milan points out is sometimes disruptive. I find that frequently I must repeat the key stroke sequence several times to stop a traceroute, but I find that the keystroke sequence of CTRL + shift + 6 is effective in stopping traceroute (or extended ping).
Rick
Rick
Sometimes you need to hit the X twice.
hold: ctrl+shift+6
release and press x x
