03-22-2013 01:01 PM - edited 03-04-2019 07:22 PM
So, I have a mixed vendor network with a bunch of 3560s as my core, and a different vendor for the remote locations.
When I attempt to ping one of the objects at a remote location it works as expected, however traceroute produces the following result. There is connectivity so I'm trying to understand why it works this way.
(I already checked the other posts about ping, and yes I know it works over UDP, and there's no firewalls in place here, so I struck out early googling)
Is there a different tool besides traceroute that works in a switched environment?
Output from results:
Main#ping 10.1.15.195 (Random hardware)
Sending 5, 100-byte ICMP Echos to 10.1.15.195, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/3/8 ms
Main#trace 10.1.15.195
Tracing the route to 10.1.15.195
1 * * *
2 * * *
3 * * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
03-22-2013 03:47 PM
Hello
it is possible that traceroute replies have been denied for this host/network
You can enable a debug between hosts to verify this
Access- list 100 permit Icmp host x.x.x.x host y.y.y.y
Access-list 100 permit Icmp host y.y.y.y host x.x.x.x
Debug ip packets 100
traceroute 10.1.15.195
Res
Paul
03-23-2013 04:48 AM
To begin with,Go on each hop begining to the immediately connected device to which packets are being forarded and perform debugs or ACL on input interface to see if you see hits. if yes then the packets are hitting it.
whether it switch or router generally the trace packets are process sitched as it has the ttl1, means the packet termintes on the device itslef hence it will be process switched.
generally you do not see traceoute hops if you are having some firewall or "no icmp reachable" on the interfaces downstream
reply if it helps
03-26-2013 08:25 AM
I think this answers my question.
The unit in question is apaprently directly connected and hence the packet would terminate on the cisco itself.
