03-25-2010 11:47 PM - edited 03-04-2019 07:56 AM
Hi friends ,
can any of you explain the trace route o/p here . iwant to know the number of hop and total latency took to reach the destination i was tracing.
Tracing the route to 192.168.231.13
1 *
172.31.12.177 [MPLS: Label 1151 Exp 0] 36 msec *
2 172.31.1.66 [MPLS: Label 4929 Exp 0] 32 msec
172.31.2.46 [MPLS: Label 4391 Exp 0] 36 msec
3 172.31.42.194 [MPLS: Label 22311 Exp 0] 40 msec
172.31.1.218 [MPLS: Label 22311 Exp 0] 36 msec
4 172.31.2.5 [MPLS: Label 1274 Exp 0] 40 msec 36 msec 36 msec
5 59.163.55.133 40 msec * 36 msec
thanks
03-26-2010 12:11 AM
Hi friends ,
1 *
thanks
Check out the below link on studying the output for traceroute commnd hope to help !!
http://www.exit109.com/~jeremy/news/providers/traceroute.html#reading
Ganesh.H
03-26-2010 04:16 AM
Hello Vicky,
the destination is 5 hops away.
at hops 1,2,3 there are two different path options
at hop 1 one of the two next-hops has probably no ip unreachables configured (or some commands related to MPLS ) and does not provide an answer
you get a round-trip-time delay information (two way). latency is single way.
Hope to help
Giuseppe
03-26-2010 10:41 PM
Many thanks Giuseppe
regards
03-30-2010 05:35 AM
hi,
can anyone explain what is EXP 0 / EXP
thnx in advance.
Rajeev.S
03-30-2010 06:20 AM
Hello Rajeev,
MPLS header has a 3 bits wide EXP field that can be used for QoS purposes, so the output reports the value of EXP field in MPLS header.
standard behaviour is that EXP bits are a copy of IP precedence bits of the IP packet carried inside the MPLS frame.
to be noted multiple MPLS labels (label stack) can be in use but the show refers to the most external label.
the MPLS header contains also a TTL 1 byte field that can be a copy of IP packet TTL byte or not.
This means that MPLS hops can be hidden in a traceroute started by a customer depending on the settings of mpls propagate-ttl
Hope to help
Giuseppe
Cisco will donate $1 to the Red Cross Haiti fund for every rated post!
