track ip route command
hanwucisco
I've configured a very simple scenario, why is it showing the is UP?
R1----R2, ip add 1.1.1.1 is a loop interface on r1.
on R2,
track 10 ip route 1.1.1.0 255.255.255.0 metric threshold
threshold metric up 99 down 100
and
ip route 1.1.1.0 255.255.255.0 1.1.12.1 250
but, the show track indicate it is up.
R2#sh track
Track 10
  IP route 1.1.1.0 255.255.255.0 metric threshold
  Metric threshold is Up (static/0/1)======================>why is it up?
    7 changes, last change 00:05:33
  Metric threshold down 100 up 99
  First-hop interface is Serial0/0
thanks,
Han
douhanm
It seems you are comparing your metric track with the admin distance of the route, those are different things.
Yes, I assuem it is the AD. But it isnt, what it could be? I mean how can you compare the metrics from different protocols? and in IOS, there is a range for this paramenter, 0-255.
thanks,
Han
