track list boolean and questions
Lei.LIM
Hi all
Several tests are under way using this topology.
in case R1 - > R7
Only static routing should be used.
R1's config
track 1 list boolean and
object 2
object 3
track 2 ip sla 57 reachability
track 3 ip sla 35 reachability
ip sla 35
icmp-echo 1.1.35.1 source-interface GigabitEthernet0/1
frequency 5
ip sla schedule 35 life forever start-time now
ip sla 57
icmp-echo 1.1.57.1 source-interface GigabitEthernet0/1
frequency 5
ip sla schedule 57 life forever start-time now
ip route 7.7.7.7 255.255.255.255 GigabitEthernet0/1 1.1.13.2 track 1
ip route 1.1.35.0 255.255.255.0 GigabitEthernet0/1 1.1.13.2
ip route 1.1.57.0 255.255.255.0 GigabitEthernet0/1 1.1.13.2
ip route 7.7.7.7 255.255.255.255 GigabitEthernet0/0 1.1.12.2 100
in this situation
If even one link between R3-R5 (1.1.35.0) or R5-R7 (1.1.57.0) are disconnected, the routing from R1 to R7 is changed to Gi0/0.
If only R5-R7 (1.1.57.0) is disconnected and Gi0/0/0 of R1 is shut down, routing for 7.7.7.7 is dropped from R1.
Is there a way to change routing to R1->R3->R4->R6->R8->R7 in this situation?
When R5-R7 (1.1.57.0) and R1 Gi0/0 are shut down
Many thanks
Lei.
mlund
Level 7
Level 7
with "ip route 7.7.7.7 255.255.255.255 GigabitEthernet0/1 1.1.13.2 110" this will kick in when the other 2 fails
/Mikael
Hi Mikael
OK I will test it
