Tracking an IP route within a VRF
pbelletty
Hi Folks,
The command to track a route is
track <track number> ip route <ip address> <mask> reachability
This assumes that the route is in the global routing table.
What if you want to track a route that is in a VRF. There does not appear to be a way of doing this as the above command is not vrf aware.
Any idea how this could be done?
Look forward to hearing from you.
Phil
Hello
You can do this in the track command it self
example:
ip vrf stan
 rd 1:10
track 10 ip route 1.1.1.1/32 reachability
 ip vrf stan
res
Paul
sent from iphone
Kind Regards
Paul
6 Replies 6
Julio E. Moisa
If you are using IP SLA it should be included into the VRF as well.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Many thanks for the reply.
Unfortunately I am not using IP SLA as I do not wish to generate any additional traffic, I just want to monitor the existence of a route which I have already learnt via bgp.
Any other thoughts?
Phil
I think I have found the solution.
After entering the track command you can enter a sub command to specify the vrf eg..
track 99 ip route 10.10.10.10 255.255.255.255 reachability
ip vrf red
This is configurable in version 15.2.4
I'll give it a try in a live environment and let you know how I get on.
Phil
ok thank you.
Hello
example:
ip vrf stan
 rd 1:10
 ip vrf stan
res
Paul
sent from iphone
Kind Regards
Paul
Hi All
Thanks for all the replies and your help in finding a solution.
Phil
