Tracking?
anowell
<p>I have an 1841 with two internet circuits and I'm wanting to configure the circuits for failover.  Is there a way to have the router ping ISP1s default-gateway and if it fails use ISP2s gateway?  Please note that it is imperative I track an IP address rather then the state of the WAN interfaces.</p>
<p>Thanks in advance!</p>
Gregory Camp
Check out this link.  You can use IP SLA and link a track object to it.
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html
Anthony
The link provided by Greg is pretty good and should show you what you need to do. I set up something pretty similar to what you describe. I did it on 2800 rather than 1800 but it should work well for you on your 1841.
Rick
Rick
