traditional license to smart license conversion
paul amaral
Level 4
Level 4
I have an issue where a customer bought a router, about 2 years ago, used and bundled with some licenses. If this router is upgraded to  IOS 16.12.x the traditional PAK permanent licenses goes away and instead smart licensing is enabled. I know that anything after IOS 16.10 uses smart license but what happens to a router that was bought used with licensing? Can this somehow converted to smart licensing? Or does Cisco not accept this?  I never ran into this before and usually the customer has the login associated with the PAK/license which can be converted. What are my options here?
I know if you have a login with access to the PAKs via the Cisco license website it can be converted to smart license but what happens when you don’t have a register user but your router does have the PAKS/license installed.
Looking for some direction on this.
Paul
balaji.bandi
You can convert PAK to a smart License for the new version of code 16.12.X mandatory smart License.
(if you have do not have an account, worth contact licese@cisco.com - can help you) - your Router work as expected with RTU License.
here is the video :
https://www.youtube.com/watch?v=EgwlfVTJfag
https://software.cisco.com/web/fw/softwareworkspace/smartlicensing/ssmcompiledhelps/c_Convert_Classic_Licensing.html
BB
This brief video shows how to assign a PAK to a Smart Account in the License Registration Portal (LRP).
Deepak Kumar
Yes, it is possible and BB already shared all details.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
