08-14-2020 05:57 AM - edited 08-14-2020 05:58 AM
Hey Guys,
I have configured BGP multipath to get BGP load balancing between two ASs on my company.
The scenario is in annex. Basically i have two routers interconnected with 2 links running in different ASs.
BGP multipath was configured so that i could achieve load balacing.
The problem is i'm seeing an assymetry on my traffic. output traffic is going through one interface and the replies are going from the other one. Just a ping test right..
As per CEF i'm seeing that it would be using a single path. Why this is not happening? Using a single link?
ROUTER1#sh cef state
CEF Status:
RP instance
common CEF enabled
IPv4 CEF Status:
CEF enabled/running
dCEF disabled/not running
CEF switching enabled/running
universal per-destination load sharing algorithm, id 9B4C5E9D
IPv6 CEF Status:
ROUTER3#sh cef state
CEF Status:
RP instance
common CEF enabled
IPv4 CEF Status:
CEF enabled/running
universal per-destination load sharing algorithm, id F968AD29
IPv6 CEF Status:
ROUTER1#sh ip cef exact-route 10.10.0.1 10.20.0.1
10.10.0.1 -> 10.20.0.1 =>IP adj out of GigabitEthernet0/3, addr 192.168.1.2
ROUTER3#sh ip cef exact-route 10.20.0.1 10.10.0.1
10.20.0.1 -> 10.10.0.1 =>IP adj out of GigabitEthernet0/3, addr 192.168.1.1
ROUTER1#sh int g0/1
GigabitEthernet0/1 is up, line protocol is up
Hardware is iGbE, address is 5000.0001.0001 (bia 5000.0001.0001)
Internet address is 192.168.0.1/24
MTU 1500 bytes, BW 145000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Unknown, Unknown, link type is auto, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 91000 bits/sec, 100 packets/sec
170 packets input, 27984 bytes, 0 no buffer
Received 5 broadcasts (0 IP multicasts)
0 watchdog, 0 multicast, 0 pause input
62966 packets output, 7172653 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
ROUTER1#sh int g0/3
GigabitEthernet0/3 is up, line protocol is up
Hardware is iGbE, address is 5000.0001.0003 (bia 5000.0001.0003)
Internet address is 192.168.1.1/30
Last input 00:00:06, output 00:00:04, output hang never
30 second input rate 90000 bits/sec, 99 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
63540 packets input, 7252177 bytes, 0 no buffer
440 packets output, 44873 bytes, 0 underruns
BGP for R1:
router bgp 1
bgp router-id 10.10.10.2
bgp log-neighbor-changes
neighbor 192.168.0.2 remote-as 2
neighbor 192.168.1.2 remote-as 2
address-family ipv4
redistribute ospf 100
neighbor 192.168.0.2 activate
neighbor 192.168.1.2 activate
maximum-paths 2
exit-address-family
BGP for R2:
router bgp 2
bgp router-id 10.10.10.4
neighbor 192.168.0.1 remote-as 1
neighbor 192.168.1.1 remote-as 1
address-family ipv4
neighbor 192.168.0.1 activate
neighbor 192.168.1.1 activate
maximum-paths 2
exit-address-family
IP Route for R1:
ROUTER1#sh ip route 10.20.0.1
Routing entry for 10.20.0.0/24
Known via "bgp 1", distance 20, metric 2
Tag 2, type external
Redistributing via ospf 100
Advertised by ospf 100 subnets
Last update from 192.168.0.2 00:45:11 ago
Routing Descriptor Blocks:
* 192.168.1.2, from 192.168.1.2, 00:45:11 ago
Route metric is 2, traffic share count is 1
AS Hops 1
Route tag 2
MPLS label: none
192.168.0.2, from 192.168.0.2, 00:45:11 ago
AS Hops 1
Route tag 2
MPLS label: none
IP Route for R2:
ROUTER3#sh ip route 10.10.0.1
Routing entry for 10.10.0.0/24
Known via "bgp 2", distance 20, metric 2
Tag 1, type external
Last update from 192.168.1.1 00:45:35 ago
192.168.1.1, from 192.168.1.1, 00:45:35 ago
AS Hops 1
Route tag 1
MPLS label: none
* 192.168.0.1, from 192.168.0.1, 00:45:35 ago
AS Hops 1
Route tag 1
MPLS label: none
Solved! Go to Solution.
08-14-2020 06:48 AM - edited 08-14-2020 07:25 AM
Hello @filipequintela ,
what you see is normal for the following reasons:
a) CEF load balancing is flow based that is given a pair of addresses sourceIP destinationIP they make a flow and they use a single exit link ( this is done to avoid the possible out of order issues that per packet load balancing can cause).
b) the exit interface is chosen using an algorithm that involves the less significant bits of sourceIP , destinationIP and a seed value that is node specific and can change after a router reload.
The operation is a binary EXOR :
10.10.0.1 EXOR 10.20.0.1 EXOR SEED gives a value that makes a choice on first router.
On the second router what changes is its own SEED and this leads to a different choice of the exit interface.
To be sure that mulipath is happening you need to check
show ip bgp 10.10.0.0
show ip bgp 10.20.0.0
you should see one path as best and the other one labelled as "m" that means taken by multipath
To see load balancing in action you need multiple flows with different sourceIP/ destination IP
Edit:
reviewing your network diagram what happens does not even qualify for asymmetric routing it is simple the result of different choices made by the two eBGP peers that have two links between themselves as explained above for the way CEF works.
Hope to help
Giuseppe
Edit:
Hope to help
Giuseppe
08-14-2020 06:49 AM
08-14-2020 07:28 AM
Hello Joseph,
in this specific case looking at the network diagram we see thay only two EBGP routers are involved and only two BGP ASes.
So this scenario should not need the as path relax to work as the two eBGP sessions are with the same peer AS.
Hope to help
Giuseppe
08-14-2020 08:19 AM
