Traffic Capture on Cisco ASR 1002 Routers
ju.mahieu
I have to set up a traffic capture on my Cisco ASR 1002 router. The router is under 12.2(33)XNB2, RELEASE SOFTWARE (fc2) version.
My configuration is like below:
BB-1(config)#monitor session 1 type local
BB-1(config-mon-local)#source interface gigabitEthernet 0/0/0
BB-1(config-mon-local)#destination interface gigabitEthernet 0/0/3
It doesn't work. No packet seems to be captured on my traffic Sniffer plugged in Gi0/0/3.
Thanks for you help,
Ju
6 Replies 6
b.julin
Level 3
Level 3
I haven't tried it on the ASR yet. Maybe zone security gets in the way?
At any rate, depending on what you need it for, "debug ip packet #ACL" works for debugging. Not the same thing I know.
Thank you for your solution, but it's not really what I'm looking for. I want to capture all L2 and L3 packets between Provider Switch and my ASR router.
I hope someone else can help me.
I tried to set this up also on my ASR 1002 Version 12.2(33)XNE and all I can seem to capture is the odd ethernet frame that Wireshark identifies as a DEC DNA Remote Console frame.
My monitor session config looks like this:
Session 1
Type                   : Local Session
Status                 : Admin Enabled
Source Ports           :
    Both               : Gi0/0/0
Destination Ports      : Gi0/1/0
interface configs looks like this:
interface GigabitEthernet0/0/0
description SSH FEED
bandwidth 50000
ip address 10.1.2.3 255.255.255.248
ip access-group EXTERNAL-FIREWALL in
no ip redirects
ip nat outside
ip virtual-reassembly
ip route-cache same-interface
ip policy route-map IPSEC-ROUTEMAP
no negotiation auto
crypto map GENERIC
end
interface GigabitEthernet0/1/0
no ip address
negotiation auto
end
Any ideas as to why I'm not capturing any of the traffic I expect to see leaving Gi0/0/0 .
Thanks.
John
I dunno, the devel team is too busy adding support for VTP over MPLS with VRF-aware QinQ DPI pruning?  :-)
I still haven't tried monitor sessions on mine, but I do note there is a "debug monitor" command, in case you hadn't noticed it.
Thanks... didn't know about the "debug monitor" command so I tried it and guess what?? It revealed nothing. Nada. No surprise there.
paolo bevilacqua
It works a little different on the ASR
on IOS:
debug platform hardware qfp active feature ipsec datapath trace
debug platform hardware qfp active feature ipsec datapath info
RP console -- telnet to fp console (telnet fp0-0)
fp console:
tail -f cpp_cp_F0-0.log
(Thanks Trent!!)
