Traffic from sub-interface subnets failing to AWS
jroy777
I have an ASR1001-x with a single 10G interface to a switch on the LAN. I cannot pass traffic from the sub interface subnets to AWS network connected on WAN. The Lan interface subnet 192.168.50.0/23 passes traffic correctly. the other two do not. Can anyone see a problem here?
interface TenGigabitEthernet0/0/0
mtu 3800
no ip address
interface TenGigabitEthernet0/0/0.2900
description "Direct Connect to Amazon VPC or Transit Gateway on AWS Cloud"
encapsulation dot1Q 2900
ip address 169.254.38.182 255.255.255.252
interface TenGigabitEthernet0/0/1
description "Prod DBNET access"
ip address 192.168.51.249 255.255.254.0 <----Ping from here to AWS 169.254.38.181 works
no ip proxy-arp
ip nbar protocol-discovery
interface TenGigabitEthernet0/0/1.4
encapsulation dot1Q 4
ip address 10.1.0.4 255.255.254.0 <----Ping from here to AWS 169.254.38.181 Does NOT
interface TenGigabitEthernet0/0/1.35
encapsulation dot1Q 35
ip address 10.10.2.4 255.255.255.0 <----Ping from here to AWS 169.254.38.181 Does NOT
router bgp 64514
bgp log-neighbor-changes
neighbor 169.254.38.181 remote-as 64513
neighbor 169.254.38.181 password 7777777
address-family ipv4
network 10.1.0.0 mask 255.255.254.0
network 10.10.2.0 mask 255.255.255.0
network 169.254.38.180 mask 255.255.255.252
network 192.168.50.0 mask 255.255.254.0
neighbor 169.254.38.181 activate
exit-address-family
AWS-DC-RTR#show bgp
% Command accepted but obsolete, unreleased or unsupported; see documentation.
BGP table version is 15, local router ID is 192.168.51.249
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
t secondary path, L long-lived-stale,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
*> 10.1.0.0/23 0.0.0.0 0 32768 i
* 169.254.38.181 0 64513 i
*> 10.10.2.0/24 0.0.0.0 0 32768 i
*> 10.22.0.0/16 169.254.38.181 0 64513 i
*> 10.31.0.0/16 169.254.38.181 0 64513 i
*> 10.32.0.0/16 169.254.38.181 0 64513 i
*> 10.33.0.0/16 169.254.38.181 0 64513 i
*> 169.254.38.180/30 0.0.0.0 0 32768 i
*> 192.168.50.0/23 0.0.0.0 0 32768 i
AWS-DC-RTR#
AWS-DC-RTR#ping 169.254.38.181 source 192.168.51.249
Sending 5, 100-byte ICMP Echos to 169.254.38.181, timeout is 2 seconds:
Packet sent with a source address of 192.168.51.249
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/28/29 ms
AWS-DC-RTR#ping 169.254.38.181 source 10.10.2.4
Packet sent with a source address of 10.10.2.4
Success rate is 0 percent (0/5)
AWS-DC-RTR#ping 169.254.38.181 source 10.1.0.4
Packet sent with a source address of 10.1.0.4
AWS-DC-RTR#
Can you share show ip bgp in AWS
Also you ping the AWS peer IP? This IP is for underlay IGP' try ping IP advertise by bgp not bgp peer
MHM
12 Replies 12
jroy777
It almost acts like it is not in layer3?
AWS-DC-RTR#sh interfaces tenGigabitEthernet 0/0/1
TenGigabitEthernet0/0/1 is up, line protocol is up
  Hardware is BUILT-IN-2T+6X1GE, address is a0e0.af94.5001 (bia a0e0.af94.5001)
  Description: "Prod DBNET access"
  Internet address is 192.168.51.249/23
  MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive not supported
  Full Duplex, 10000Mbps, link type is force-up, media type is unknown media type
  output flow-control is on, input flow-control is on
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 64850000 bits/sec, 5485 packets/sec
  5 minute output rate 473000 bits/sec, 817 packets/sec
     850976125 packets input, 1243947372294 bytes, 0 no buffer
     Received 625190 broadcasts (0 IP multicasts)
     0 watchdog, 553199 multicast, 0 pause input
     118135807 packets output, 8511093703 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     144530 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
     1 carrier transitions
AWS-DC-RTR#sh interfaces tenGigabitEthernet 0/0/1.4
TenGigabitEthernet0/0/1.4 is up, line protocol is up
  Internet address is 10.1.0.4/23
  Encapsulation 802.1Q Virtual LAN, Vlan ID  4.
AWS-DC-RTR#sh interfaces tenGigabitEthernet 0/0/1.35
TenGigabitEthernet0/0/1.35 is up, line protocol is up
  Internet address is 10.10.2.4/24
     reliability 255/255, txload 1/255, rxload 4/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  35.
AWS-DC-RTR#
MHM
balaji.bandi
Where is that interface connected - if other side also trunk and can understand vlan tagging
try below config :
no ip address
no shutdown
interface TenGigabitEthernet0/0/1.X   (X choose the different VLAN number here)
encapsulation dot1Q X   (same replace X with vlan number)
no ip proxy-arp
BB
can you post a screenshot of our AWS Direct Connect --> Virtual Interfaces management console ?
jroy777
jroy777
It ended up the AWS engineer placed my routes on AWS side. Once he removed, It came up.
The AWS is underlying and your prefix is overlying that must separate
That explain issue
Thank alot for updating
MHM
jroy777
Thanks to all you Guru's, you are Greatly Appreciated!
jroy777
Something else has popped up. The ASR is connected to a FortiSwitch and the FortiSwitch is connected to an HP 5700 switch stack in our DMZ. The DMZ stack has 2 vlan's 1)DMZ hosts 10.1.0.0/23 (native vlan1)  2)UAT hosts (vlan 35). I set the port on the HP to vlan 35 because the port on the FortiSwitch is set as 35 and upstream towards AWS is also dot1q 35. I cannot pass any traffic on vlan 35. I can pass traffic on DMZ subnet without issue. SEe drawing. Any recommendations? Yellow boxes show whats left that still is not working (only vlan35)
Hosts in the UAT cannot ping the ASR 10.10.2.4 interface
are all links between the UAT hosts and the ASR layer 2 links ? Are you using trunks ? I guess it would help to see the relevant configs...
Here is Cisco:
mtu 8500
no ip address
no ip proxy-arp
Here is FortiSwitch: Only relevant portions for ports 25 thru 28 that are in use.
#global_vdom=1
config system global
set dst enable
set hostname "FortiSW-424E"
end
config switch vlan-tpid
edit "default"
set ether-type 0x8100
next
end
config switch physical-port
next
edit "port25"
set lldp-profile "default-auto-isl"
set speed auto-module
next
edit "port26"
next
edit "port27"
next
edit "port28"
next
edit "internal"
next
end
config switch vlan
edit 1
set description "dbnet"
next
edit 35
set description "UAT"
next
edit 4
set description "dmz"
next
end
config switch interface
next
edit "port25"
set snmp-index 25
next
edit "port26"
set native-vlan 4
set snmp-index 26
next
edit "port27"
set native-vlan 35
set snmp-index 27
next
edit "port28"
set allowed-vlans 1,4,35
set edge-port disabled
set snmp-index 28
next
edit "internal"
set stp-state disabled
set snmp-index 29
next
end
config switch stp instance
edit "0"
config stp-port
next
edit "port25"
next
edit "port26"
next
edit "port27"
next
edit "port28"
next
edit "internal"
next
end
next
edit "15"
set vlan-range 4094
next
end
next
end
config system interface
next
edit "internal"
set ip 192.168.50.41 255.255.254.0
set allowaccess ping https ssh
set type physical
set alias "internal"
set snmp-index 30
next
end
config router bgp
config redistribute "connected"
end
end
FortiSW-424E #
Here is HP Switch:
The HP gives me multiple link types: access, trunk or hybrid
