Traffic Limiting Scheme
jeffbriones
Hi guys,
i want to implement some traffic limiting scheme as conclusion to my previous posted topic. I just want to clear things up which is more desirable to use, policing or shaping? I found out that policing drops packets unlike shaping. So which do you think is ideal to use. Im finalizing my setup now and will deploy it.
Thanks.
jeff
mheusinger
Level 10
Level 10
in short: policing drops, shaping queues packets.
Refering to your original post or describing your setup so far would really help a lot.
Regards, Martin
Jeff,
As I have followed your last post, let me respond as well.
Shaping buffers non-compliant packets to the extent possible with the amount of buffering available. If you are consistently sending packets at a higher rate than the shaping rate configured, you will eventually drop packets even if shaping. Policing drops non-compliant packets immediately - there is no buffering.
Overall, you will see better performance with shaping since you drop less packets overall by absorbing any temporary bursts.
Hope that helps - pls do remember to rate posts that help.
Paresh
