Traffic Shaping and LLQ... weird behavior (is it normal?)
I have a problem with LLQ and the router letting go through itself more traffic than it should be allowed too, so my queues seem not to be applying the exact BW limitations i have configured…
I think it has to be with the router generating 670Kbps aprox INSTEAD of the 512Kbps it should be generating for the parent policy (SHAPING512), WHY ON EARTH is allowing more traffic… I understand the priority queue IS WORKING cuz is actually policing to the limit established (384Kbps) but because the router is letting go through itself more bits than what it should I see all my other queues going above of what they should!!!!
Omg I have been trying to figure this out a lot of hours (a LOT hahaha) so… if someone could help me out here it would be sooooooooo great!!!
NOTES:
I am using for my lab 1861x2 with c1861-adventerprisek9-mz.151-3.T4.bin servers are win7 boxes and the unknown traffic is iperf...
for some reason the max-reserved-bandwidth command wasnt necessary, the interface dont recognize the command nor gave the error when reserving more than a threshold ...
if you need any other information to help just ask !
Thanks in advance!!!!
My policy is being applied on my server side where the traffic is generating outbound (where SHAPE512 should be establishing the limit for my outbounf traffic):
Output obtained of a “show policy-map”
  Policy Map SHAPE512
    Class class-default
      Average Rate Traffic Shaping
      cir 512000 (bps)
      service-policy PRIORITY
Policy Map PRIORITY
    Class HTTP
      priority 75 (%)
    Class FTP
      bandwidth 20 (%)
    Class class-default
      fair-queue
       packet-based wred, exponential weight 9
      class    min-threshold    max-threshold    mark-probablity
      0       -                -                1/10
      1       -                -                1/10
      2       -                -                1/10
      3       -                -                1/10
      4       -                -                1/10
      5       -                -                1/10
      6       -                -                1/10
      7       -                -                1/10
I am applying the policy on my WAN interface from the server side where traffic is being generating in an outbound direction…
interface FastEthernet0/0
description WAN
bandwidth 512
ip address 172.16.0.1 255.255.255.252
ip nbar protocol-discovery
load-interval 60
duplex auto
speed auto
service-policy output SHAPE512
end
Then when trying to check the policy with the “show policy-map interface” command it seems like if it was working just fine:
FastEthernet0/0
  Service-policy output: SHAPE512
    Class-map: class-default (match-any)
      624700 packets, 260135526 bytes
      1 minute offered rate 671000 bps, drop rate 158000 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 26/40745/0
      (pkts output/bytes output) 584009/210207402
      shape (average) cir 512000, bc 2048, be 2048
      target shape rate 512000
      Service-policy : PRIORITY
        queue stats for all priority classes:
          (queue depth/total drops/no-buffer drops) 0/0/0
          (pkts output/bytes output) 70320/88516627
        Class-map: HTTP (match-all)
          109401 packets, 138343257 bytes
          1 minute offered rate 386000 bps, drop rate 158000 bps
          Match: protocol http
          Priority: 75% (384 kbps), burst bytes 9600, b/w exceed drops: 39081
        Class-map: FTP (match-all)
          65230 packets, 92533763 bytes
          1 minute offered rate 227000 bps, drop rate 0 bps
          Match: protocol ftp
          Queueing
          (queue depth/total drops/no-buffer drops) 2/4/0
          (pkts output/bytes output) 65137/92401765
          bandwidth 20% (102 kbps)
          450069 packets, 29258506 bytes
          1 minute offered rate 56000 bps, drop rate 0 bps
          Match: any
          Queueing
          (queue depth/total drops/no-buffer drops/flowdrops) 22/1660/0/0
          (pkts output/bytes output) 448552/29289010
          Fair-queue: per-flow queue limit 16
            Exp-weight-constant: 9 (1/512)
            Mean queue depth: 10 packets
            class     Transmitted       Random drop      Tail/Flow drop Minimum Maximum Mark
                      pkts/bytes    pkts/bytes       pkts/bytes    thresh  thresh  prob
            0          438377/28532748      250/13584        123/6666              20            40  1/10
            1               0/0               0/0              0/0                 22            40  1/10
            2               0/0               0/0              0/0                 24            40  1/10
            3              63/7838            0/0              1/154               26            40  1/10
            4               0/0               0/0              0/0                 28            40  1/10
            5            9300/688200        108/7992         169/12506             30            40  1/10
            6             812/60224           0/0              0/0                 32            40  1/10
            7               0/0               0/0              0/0                 34            40  1/10
But what it’s so so so confusing is that even those statistics seems to be fine, the downloads from the client side tell another story!!!! the FTP traffic is pretty solid on being above HTTP or being just at the same rate as HTTP…
FTP Transfer
HTTP Transfer
Confirmed by NBAR rates, that at some moments http go less than that and ftp goes a little up…
FastEthernet0/0
Last clearing of "show ip nbar protocol-discovery" counters 03:28:17
                                               Input                    Output
   Protocol                 1min Bit Rate (bps)      1min Bit Rate (bps)
   http                                   9000                         377000
   ftp                                      4000                        228000
   rtp                                      0                             0
   eigrp                                   0                             0
   edonkey                              0                             0
   rtcp                                     0                             0
   h323                                   0                             0
   icmp                                   0                             0
   unknown                              3335000                  57000
   Total                                    3348000                  662000
WHY ON EARTH THE TOTAL SUM OF BITS per second is 670Kbps aprox D: !!!! that rate is pretty solid and actually can be confirmed by the statistics on the client machine
Any help or idea would be greatly appreciated!!!!
0 Replies 0
