traffic shaping capacity
se160412345
I have 50Mb Merto-E circuit and want to traffic shape. I currently have a 2901.
Does the 2901 have the capacity to traffic shape a 50Mb circuit?
Kelvin Willacey
Level 4
Level 4
You should be able to shape the traffic to whatever you may need. Are you asking if the router has the throughput capacity to support a 50 Mbps link? I don't think it can support it but I will try and find the link.
http://anticisco.ru/pubs/ISR_G2_Perfomance.pdf
hi,
The Cisco 2900 Series enables deployment in high speed WAN environments with concurrent services enabled up to 75 Mbps.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The 2901 should support traffic shaping.  Cisco recommends the 2901 for up to 25 Mbps although it also documents its peak thoughput at 3 Gbps.
The real issue is whether your 2901 can deal with your 50 Mbps.
