Traffic Shaping - Frame Relay
js358
Hi All:
Taking my first stab a traffic shaping on a Frame Relay Circuit. Read a Cisco article on it but it doesn't seem as straight forward as I hoped.
We have 3 T1 MFR circuit and I want to allow smtp let's say, to 25% of the bandwidth out. How can I accomplish this in the easiest manner possible. Nothing fancy needed.
Thanks.
Joe
8 Replies 8
mheusinger
Level 10
Level 10
Hello Joe,
well what is easy in IT? ;-)
One solution is:
class-map match-all SMTP
match protocol smtp
policy-map FRshape
class SMTP
shape average percent 25
interface Serial0/0
encapsulation frame-relay IETF
frame-relay traffic-shaping
interface Serial0/0.100 point-to-point
ip address ...
frame-relay interface-dlci 100
class DLCIshape
map-class frame-relay DLCIshape
frame-relay cir 64000
service-policy output FRshape
What you do there is to specify smtp traffic to belong to the class SMTP. Then you define a policy that does shape the traffic in this class to 25% of the interface bandwidth and apply it to the DLCI 100 with the help of a FR class.
You can monitor the outcome by "show policy interface Serial0/0.100". Adjust the config to your interface naming, DLCI number and bandwidth.
Hope this helps! Please rate all posts
Regards, Martin
Thanks Martin - I'll give it a try
Martin - tried this and had some difficulties. Defined the policy fine but had an issue mapping it to an interface. Also, from the posts below, I also need to understand the frame-relay cir 64000 line in the config. I am assuming that this is total available bandwidth on the circuit....in this case 64K ? For a 3T bundle we would be talking roughly 4600K?
Perhaps if I posted my config it would help. Appreciate your input.
ip cef
no ip domain lookup
no ip bootp server
frame-relay switching
no frame-relay address registration ip
controller T1 1/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24 speed 64
controller T1 1/1
framing esf
linecode b8zs
controller T1 1/2
framing esf
linecode b8zs
controller T1 1/3
framing esf
linecode b8zs
interface MFR1
mtu 4470
no ip address
no ip proxy-arp
no ip route-cache cef
no ip mroute-cache
load-interval 30
no arp frame-relay
frame-relay multilink bid to gw
frame-relay lmi-type ansi
interface MFR1.500 point-to-point
ip address 140.x.x.x 255.255.255.252
no ip proxy-arp
ip nat outside
no arp frame-relay
no cdp enable
frame-relay interface-dlci 500 IETF
interface FastEthernet0/0
description PRODUCTION
ip address 10.0.2.1 255.255.255.0
ip nat inside
ip route-cache same-interface
no ip mroute-cache
duplex auto
speed auto
no cdp enable
hold-queue 450 in
interface FastEthernet0/1
description CORP LINK
ip address 10.0.4.1 255.255.255.0
ip nat inside
duplex auto
speed auto
no cdp enable
interface FastEthernet1/0
no ip address
duplex auto
speed auto
no cdp enable
interface Serial1/0:0
mtu 4470
bandwidth 1536
no ip address
no ip redirects
no ip proxy-arp
encapsulation frame-relay MFR1
no arp frame-relay
interface FastEthernet1/1
description LINK TO 3x FIREWALL WAN PORT
ip address 65.x.x.x 255.255.255.0
duplex auto
speed auto
no cdp enable
interface Serial1/1:0
mtu 4470
bandwidth 1536
no ip address
no ip redirects
no arp frame-relay
interface Serial1/2:0
mtu 4470
bandwidth 1536
no ip address
no ip redirects
no arp frame-relay
you should apply the service-policy to the FR PVC, something like:
interface MFR1
mtu 4470
no ip address
no ip proxy-arp
no ip proxy-arp
ip nat outside
no arp frame-relay
no cdp enable
class DLCIshape
frame-relay cir 4600000
What are the problems you are facing, when trying to apply the policy?
Hope this helps! Please rate all posts.
Regards, Martin
The problem I encountered was with the sub-interface. I'm not quite sure what the line class DLCIshape accomplishes and what command was issued that resulted in that line being added to the sub-interface. Everything else was pretty straightforward.
I also had a question regarding the bandwidth parameter which I see now is total bandwidth of the bundle expressed in bytes..correct?
Thanks alot Martin, appreciate your time on this.
Joe
in addition to Martin´s post, and if you want to read up a little more on Frame Relay Traffic Shaping, you might want to have a look at the link below, which is (I think) a really good and fairly easy to understand explanation of the technology:
Understanding Frame Relay Traffic Shaping
http://www.internetworkexpert.com/resources/01700368.htm
GP
Just a quick question. Wouldn't configuring a CIR of 64k in the map-class effectively shape SMTP to 25% of that (resulting in shaping SMTP @ 16k) ? When configured this way, I believe it will use the configured CIR as opposed to the total bandwidth available on the MFR bundle. Could be wrong.
Just read the initial reply again. I see the note where it suggests adjusting BW, interface, etc...
