837 brouser interface not working
seangentry
Hi Guys,
I just received a 837 router and change the address of "ethernet 0 " to 192.168.100.1. After that I could not connect to the router via the brouser. I changed the address back to 10.10.10.1 and still could not access it. I can access it via hyper terminal and my laptop has an ip of 10.10.10.2 given by the router. I can ping the router and my laptop but cannot get back into the setup configuration via the browser. Any help would be appreciated.
Sean
5 Replies 5
pkhatri
Level 11
Level 11
Hello Sean,
Can you try and get into the router via hyperterminal, then enter in the following command in configuration mode: 'ip http server'
The exact steps are:
router> enable
(then enter your password if prompted)
router# conf t
router(conf)# ip http server.
Hope that helps - pls rate the post if it does.
Paresh
Hi Paresh,
I tried that and it did not work. It looks like the router is not giving me an ip when I connect to it.
Maybe the dhcp is not giving me an ip on that port.
The ip that I get is 169.254.139.117 and the sub is 255.255.0.0.
Where is the config that I pasted from hyperterminal this morning.
Interface IP-Address OK? Method Status Prot
ocol
ATM0 unassigned YES NVRAM administratively down down
Ethernet0 10.10.10.1 YES NVRAM up up
FastEthernet1 unassigned YES unset up up
FastEthernet2 unassigned YES unset administratively down down
FastEthernet3 unassigned YES unset administratively down down
FastEthernet4 unassigned YES unset administratively down dow
The only thing that I need to do at this point is get back into the web interface so I'm not really cared about the ip address I'm using.
This is the first time I'm really worked on a cisco router.
I am connecting my laptop to ethernet1 via the yellow cable and the router light on the front indicated the connection is on.
Any help is appreciated.
Sean
Can you post the running configuration of this box captured using the command show run either from hypterterminal or telnet session ??
regds
Hi Guys,
Thanks for the reply.
Here is the config. I connect my laptop to the router via the yellow cable to ethernet 1 on the router.
Our " guru" in the office is away so I am trying to get into the web config again.
Thanks a million.
Sean
Building configuration...
Current configuration : 1025 bytes
version 12.3
no service pad
hostname Router
enable secret 5 $1$KHeh$u5QrKL8T4eIAt5jv86JtL1
enable password cdisupport
no aaa new-model
ip subnet-zero
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
ip address 10.10.10.1 255.0.0.0
hold-queue 100 out
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet1
no ip address
speed auto
full-duplex
interface FastEthernet2
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet3
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
ip classless
ip http server
no ip http secure-server
dialer-list 1 protocol ip permit
line con 0
no modem enable
line aux 0
line vty 0 4
password cdisupport
login
scheduler max-task-time 5000
end
Router#
I managed to get into the router via the web interface.
I hardcoded my ip on my laptop and put the correct subnet in.
Thanks for all your great suggestions.
