Traffic Shaping output info missing in 15.x
Michael Grann
Hello. Does anyone know where to find Traffic Shaping info in 15.x? I no longer see the same info in the policy-map as you see in 12.4.x release. Below is a comparison of the same exact QoS policy configured on 12.4T clearly showing TS information in the default class but has changed in 15.x.
R1#sh policy-map int f0/0
 FastEthernet0/0
  Service-policy output: SHAPE_10M
    Class-map: class-default (match-any)
      19 packets, 1356 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: any
      Traffic Shaping
           Target/Average   Byte   Sustain   Excess    Interval  Increment
             Rate           Limit  bits/int  bits/int  (ms)      (bytes)
         10000000/10000000  62500  250000    250000    25        31250
        Adapt  Queue     Packets   Bytes        Packets   Bytes     Shaping
        Active  Depth                       Delayed   Delayed   Active
        -            0              19            1356         0               0              no
Thanks in advance.
Michael G
Michael Grann
I forgot to post the 15.x otuput; here it is.
R2#sh policy-map int f0/0
 FastEthernet0/0
      14 packets, 1056 bytes
      5 minute offered rate 0000 bps, drop rate 0000 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 14/1056
      shape (average) cir 10000000, bc 40000, be 40000
      target shape rate 10000000
