1 default Gateway - How to send traffic to a different one
GRANT3779
Hi All,
I have 2 separate FWs. One of them is the Gateway of last resort for the whole LAN.
I have another FW with a different LAN side address and want to use this as the GW of Last Resort but only for a specific host on the Network.
So when traffic comes into the core from this specific host - if there is no route - use GW2 instead of the normal GW.
A - Is this possible or will it always use the gateway configured on the Core
B - I guess this is dependent on the Core IOS as to whether I can use PBR?
Richard Burts
You have not provided much detail but it seems from what you have given so far that PBR on the core would be the way to achieve the result that you want, assuming that your core supports PBR.
Rick
Rick
