Traffic Shaping Question
shanemoss
Hi folks,  I'm having some difficulty in understanding traffic shaping configuration I have inherited on an ASR.
The existing configuration is;
interface TenGigE0/0/0/1.10
service-policy output parent-shape-to-nearly-1g
policy-map parent-shape-to-nearly-1g
class class-default
  service-policy child-classify-important
  shape average 900 mbps
end-policy-map
policy-map child-classify-important
  class important
  bandwidth 50 mpbs
class-map match-any important
match access-group ipv4 acl-important
end-class-map
ipv4 access-list acl-important
10 permit ipv4 host 1.1.1.1 host 2.2.2.2
20 permit ipv4 host 1.1.1.2 host 2.2.2.2
My understanding is that important traffic should be provided a CIR of 50 Mbps and all traffic outbound from interface TenGigE0/0/0/1.10 should be shaped to 900 Mbps.
Will this existing configuration do this (I suspect it is not working as expected) or should it not be;
class important
  bandwidth 50 mbps
class class-default
Thanks in advance.
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Thanks for the replies, so what will the following do;
class important
  bandwidth 50 mbps
class class-default
will it give important traffic a CIR of 50Mbps and shape everything else to 900Mbs?  If so, what will the original policy map below do?
Nope, "important" traffic would be allowed up to full interface bandwidth.  Assuming a 10 gig interface, "important" should be able to obtain a minimum of 9.9 Gbps and a maximum of 10 Gbps.
class class-default
All traffic through that policy would be shaped to 900 Mbps, and "important" traffic will have its own queue which should be able to obtain a minimum of 50 Mbps; maximum would be 900 Mbps.
The reson I suspect there is something wrong with it is that there is an upstream 1Gig port that is carrying this traffic with a lot of outbound drops (the reason for the shaping on this ten gig subinterface was to avoid this) but this may be due to bursts exceeding the averaging shaping?
Yes, bursting is one consideration.  Adjusting the Tc down will mitigate that.
Another consideration, I believe many shapers only "measure" L3 and don't account for L2 bandwidth which an interface does.  L2 overhead percentage varies based on packet's size.  If there are many small packets, 10% might be an insufficient allowance.
PS:
The downstream gig interface cannot "see" traffic from any source but this upstream 10g interface?
5 Replies 5
justinhulsman
Shane,
I haven't ever seen a Two-Tier Policy used like this.  It looks as though the configuration was meant to give the important class 50 Mbps and shape all traffic (both important and default classes) to 900 Mbps.  It would be interesting to see what the output of "show policy-map interface TenGigE0/0/0/1.10" would look like.
-Justin
Joseph W. Doherty
Disclaimer
Posting
No, you don't want what you propose, i.e. the CIR traffic not in the child policy.
The original policy is probably okay, although the implicit (child's) class-default should be explicitly defined to use the other 850 Mbps.
class important
  bandwidth 50 mbps
class class-default
class class-default
Thanks again.
Disclaimer
Posting
class important
  bandwidth 50 mbps
class class-default
class class-default
PS:
Thanks Joseph, your reply was very helpful in clarifying this for me.  Regarding the upstream 1G interface, yes it will only "see" traffic that has been forwarded by this subinterface.
