trunking and subinterfaces
Tejas Kunte
the attached image shows what i am trying to achieve
i need to establish connectivity from subnets 10.30.5.X and 10.30.6.X (in VLAN1 and VLAN2 respectively) to subnet 10.11.35.X
i have a trunk port on my cisco 2960 that is connected to GiE0/0 on my Cisco ASA that has 2 sub-interfaces with IPs in the subnets mentioned above
my problem is i can only connect to 10.30.6.X from 10.11.35.X (and vice versa), but no connectivty to 10.30.5.X
am i missing something obvious ?
cadet alain
can you provide configs from both devices.
Regards.
Alain
i have 2 switches (have attached the config for 1, 2nd switch has the same config) and 2 ASAs in a active-passive config
port 45 on each switch (which is trunked) goes to int 0/6 on each asa
switch config
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
switchport mode trunk
interface GigabitEthernet0/1
switchport mode access
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
channel-group 1 mode active
spanning-tree portfast trunk
interface GigabitEthernet0/19
switchport access vlan 2
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
switchport access vlan 3
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
interface GigabitEthernet0/48
interface Vlan1
ip address 10.30.5.6 255.255.255.0
no ip route-cache
ip default-gateway 10.30.5.1
ip http server
ip http secure-server
logging trap notifications
ASA config
ASA Version 8.4(2)
hostname ecw17fw001
enable password z9EBartb5mE1xA7Y encrypted
passwd l/6WBlFb8xG4avQC encrypted
names
interface GigabitEthernet0/0
nameif WAN
security-level 0
ip address 207.211.113.4 255.255.255.240 standby 207.211.113.5
nameif DMZ
security-level 50
ip address 207.211.113.17 255.255.255.240 standby 207.211.113.18
nameif Production
security-level 100
ip address 10.11.35.1 255.255.255.0 standby 10.11.35.2
nameif Mgmt
security-level 100
ip address 10.11.34.1 255.255.255.0 standby 10.11.34.2
nameif MPLS
security-level 100
ip address 10.255.8.2 255.255.255.0 standby 10.255.8.3
shutdown
no nameif
no security-level
no ip address
no nameif
no security-level
no ip address
interface GigabitEthernet0/6.1
shutdown
vlan 1
nameif ASP8-Mgmt
security-level 90
ip address 10.30.5.19 255.255.255.0 standby 10.30.5.20
interface GigabitEthernet0/6.2
shutdown
vlan 2
nameif ASP8-Prod
security-level 100
ip address 10.30.6.19 255.255.255.0 standby 10.30.6.20
Tejas Kunte
I.T. Operations
eClinicalWorks
2 Technology Drive | Westborough, MA 01581
T: 508-475-0450 x10326 | F: 508-836-4466 | <> facebook.png <> twitter.png <> in.png
tejask@eclinicalworks.com | <> www.eclinicalworks.com
This transmission contains confidential information belonging to the sender that is legally privileged and proprietary and may be subject to protection under the law, including the Health Insurance Portability and Accountability Act (HIPAA). If you are not the intended recipient of this e-mail, you are prohibited from sharing, copying, or otherwise using or disclosing its contents. If you have received this e-mail in error, please notify the sender immediately by reply e-mail and permanently delete this e-mail and any attachments without reading, forwarding, or saving them. Thank you.
P Please consider the environment and only print this e-mail if necessary
fb_webuser
Level 6
Level 6
You do not need sub interfaces I think.
If you define the 3 vlans and configure the ip address on the vlan you should get routing between all 3
Posted by WebUser Stuart Gall
