trunking between two switches on different networks
tantony
I have a trunk setup between the two 172.16.64.2 and 172.16.128.2 switches, but I'm not able to ping each other.  I'm not sure what I'm doing wrong.
Please see the attached Network.pkt packet tracer file
7 Replies 7
tantony
Am I trying to do something that can't be done?
post the Packet Tracer project file (zip it first otherwise you cannot upload)...
https://drive.google.com/file/d/1NhLqlv0C5bI7WwaIEx68Q2QnX3Vg4Qt_/view?usp=sharing
I'm not sure how to upload.  It should be available on the link above
I have made some changes to your network...
I figured it out actually.  I took out ip routing and added the default gateways.  Where did you post the new configuration so I can take a look at that also?
I'm getting this from the router now.  What does this mean?  I noticed that the laptops on 172.16.128.2 are getting the correct default router, but they're getting the .64 DHCP sometimes unless I do a release/renew on them.
%DHCPD-4-PING_CONFLICT: DHCP address conflict: server pinged 172.16.128.1.
%DHCPD-4-PING_CONFLICT: DHCP address conflict: server pinged 172.16.64.1.
%DHCPD-4-PING_CONFLICT: DHCP address conflict: server pinged 172.16.64.2.
%DHCPD-4-PING_CONFLICT: DHCP address conflict: server pinged 172.16.128.2.
Have a look at the revised router configuration. You need to exclude the conflicting IP addresses...
Thank you.  I'll take a look.  I added the excluded addresses, and I'm getting the correct ones now.  No more messages in router either.
