Does 4331 supports T1 WIC card
jigarrg
I have a very old router 1721 which is currently running frame relay on WIC card and i have to move to the new router ISR 4331. Does ISR supports T1 WIC card? And can i configure frame relay on top of it?
ISR is running the latest IOS which i guess 16.6.4.
if you are talking about the first generation WIC-1T, no, it is not compatible with the ISR4331. Yiou would need the NIM-1MFT-T1/E1.
Check the compatibility matrix below:
https://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html#multiflex-trunk-voice-wan-interface-cards
Thanks Georg. This cleared my doubt.
