Trust dscp on 2911s
daved1wdiv
Hi all,
We have a few Cisco 2911's running 15.0(1r)M15.  We have Brocade FCX648S's and a TurboIron 24X that were just deployed - they will have VoIP phones connected to them.  The folks at Brocade have said that they just need the command "trust dscp" on each interface, inlcuding the uplink ports and edge routers.  The 2911's are the edge routers.  I've been unable to locate this or any similar command on the 2911's - can anyone point me in the right direction?  Thanks in advance for any and all advice.
Dave
9 Replies 9
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Cisco routers, such as your 2911, pass along L3 ToS.  I.e. there's no need to "trust dscp".
Many Cisco switches, though, if QoS is enabled will reset L3 ToS unless they are configured to trust it.
I have QoS on the Router like this:
class-map match-any remote
match protocol telnet
match protocol ssh
class-map match-any wowzee
match access-group name wowzee
class-map match-any RTMP
class-map match-any nagios
match access-group name nagios
class-map match-any rdp
match access-group name rdp
class-map match-any mssql
match protocol sqlserver
class-map match-any vertigo
match access-group name vertigo
class-map match-any vnc
match access-group name vnc
class-map match-any wideorbit
match access-group name wideorbit
policy-map QOS
class wowzee
  shape average percent 35
class vnc
  shape average percent 5
class rdp
  shape average percent 10
class wideorbit
  shape average percent 20
class vertigo
  shape average percent 17
class remote
class nagios
  shape average percent 15
class class-default
  fair-queue
policy-map apply
class class-default
  shape average percent 100
  service-policy QOS
interface Tunnel15
description This to That
bandwidth 50000
ip address 10.219.1.165 255.255.255.252
tunnel source 10.219.1.45
tunnel destination 10.219.1.53
service-policy output apply
ip access-list extended nagios
permit tcp any any eq 12489
permit tcp any any range 5666 5667
ip access-list extended rdp
permit tcp any any eq 3389
ip access-list extended vertigo
permit tcp any any eq 14050
permit tcp any any eq 14060
ip access-list extended vnc
permit tcp any any range 5800 5801
permit tcp any any range 5900 5901
ip access-list extended wideorbit
permit tcp any any range 9000 9005
ip access-list extended wowzee
permit tcp host 10.99.1.215 host 10.109.10.200
Do I still have to trust DSCP?
Thanks!
Disclaimer
Posting
No.
Hi, is this true even for a router with a switch module (EHWIC switch) installed on it?
amohabir1
mls qos trust dscp
Thanks, but I tried that command, and it wasn't available.
cause thats a switch command.
        mls (Multi Layer Switch)
in another words, routers DOES trust DSCPs by default, no need to look for another command to enable . let me know if that helps
Is this true even if the router has a switch module (EHWIC Switch) installed on it?
