Try to setup a VPN Site to Site tunnel betwen CISCO1921 and Netgear FVX538
plussier1
I don't know if anyone can help me about that.
I tried to setup a VPN between Cisco1921 and Netgear FVX538.
The vpn connexion look like to be established but i can't transfert data between the vpn tunnel.
On the Netgear i use an IKE Policy of encryption 3DES, Authentication Algorithm SHA-1, pre-shared key (cisco) and group 2 (1024bit).
for the VPN policy, trafic selection= subnet, auto policy parameters Sa lifetime=3600sec, Encryption=3DES, Integrity algorithm=SHA-1 and PFS key group 2 (1024bit).
Is it possible to have the equivalent to put on the cisco 1921 to be able to transfert data between the VPN between Cisco and Netgear Router ?
Thank You !
2 Accepted Solutions
Please remove the standard access-list 1 called in the nat statement first. Make this an extended one and add a deny statement at the top for the VPN traffic.
Make it this way:
Ip Access-list extended 102
 10 deny 192.168.116.0 0.0.0.255 192.168.2.0 0.0.0.255
20 permit 192.68.116.0 0.0.0.255 any
Call this acl in nat statement:
IP nat inside source list 102 interface g0/1 overload
Please check after this if you are able to pass traffic and update me.
If this resolves your query mark the thread answered. :)
Thanks!
Sorry about that, written in haste,  but the command is crypto map test 1 set....., then accordingly you can place everything else.
Its the crypto map name first then number.
Thanks!
15 Replies 15
jumukhi
Hi Plussier1,
If the tunnel is up then you need have any issues with the policy mismatch.
Give me more information about the issue. What exactly you mean by when you say tunnel is up? Phase-1 and 2 both up?
Please check what exactly the encap and decap counter looks like on the router? Do you have any encapsulations happening?
Command: show crypro ipsec sa peer <peer ip> detail
If you do not see any encapsulations happening then chances are that the traffic from behind the router is not making to the router itself. Please check internal routing in that case. You can also initiate traffic from the router itself if the router's interface includes the crypto access list and check if encapsulation counter increase or not.
Check if you have nat exemptions on both sides in case you are natting the traffic for internet.
From which side are you generating the traffic? Is the tunnel a static to static tunnel?
Do match the interesting traffic on both sides.
Thanks!
1) Please see the attached file for the config on the Netgear Side.
2) Please see the attached file for the config on the cisco side
and the show crypto ipsec sa peer <peer ip> detail
This is a Site-To-Site VPN Tunnel with static IP address on both site.
I'm trying to ping from to Cisco to the Netgear and vice versa. No respond to ping on both side.
sorry about that but i'm a beginner with cisco router.
Let me know !
Thank You !
Patrick Lussier
Orizonmobile
www.orizonmobile.com
Hi Plussier1,
I see the tunnel is up and interesting traffic matches on both ends.
However I see the encap and decap counter null. Have you taken this output when you initiated traffic? If yes, from where to where?
GoMobile3616#show crypto ipsec sa peer xxx.xxx.xxx.xxx detail
interface: GigabitEthernet0/1
    Crypto map tag: ToReseau2, local addr 192.168.20.100
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (192.168.116.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (192.168.2.0/255.255.255.0/0/0)
   current_peer xxx.xxx.xxx.xxx port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #pkts no sa (send) 0, #pkts invalid sa (rcv) 0
    #pkts encaps failed (send) 0, #pkts decaps failed (rcv) 0
    #pkts invalid prot (recv) 0, #pkts verify failed: 0
    #pkts invalid identity (recv) 0, #pkts invalid len (rcv) 0
    #pkts replay rollover (send): 0, #pkts replay rollover (rcv) 0
    ##pkts replay failed (rcv): 0
    #pkts tagged (send): 0, #pkts untagged (rcv): 0
    #pkts not tagged (send): 0, #pkts not untagged (rcv): 0
    #pkts internal err (send): 0, #pkts internal err (recv) 0
According to the above output I see no packets getting encapsulated and none decapsulated.
Please take this output when you initiate some traffic and attach here again.
Attach the show tech output of the router too here. Need to check the nats.
Thanks!!
Please see the show crypto ipsec command again with trafic generated on both side, look like that the cisco decrypt packet but nothing hapend on the encrypt side.
First I did a ping test from the Netgear Router to the Cisco Router.
4 Packet sent but 100% lost
Second I did a ping test from the Netgear Router (192.168.2.1) to my Laptop (192.168.116.101) connected to the cisco router.
That why we see that #pkts decaps: 8, #pkts decrypt: 8, #pkts verify: 8
Third I did a ping test from my laptop (192.168.116.101) connected to the cisco router to the netgear Router (192.168.2.1)
this is the result with the show crypto ipsec command
For the last test I did a ping test From my Laptop (192.168.116.101) connected to the Cisco router to an other Laptop (192.168.2.95) connected to the Netgear Router.
Still the same result
current_peer 216.226.46.178 port 500
#pkts decaps: 8, #pkts decrypt: 8, #pkts verify: 8  ( Ping from 192.168.2.1 network to 192.168.116.101 this is my laptop but no ping responce. )
local crypto endpt.: 192.168.20.100, remote crypto endpt.: 216.226.46.178
plaintext mtu 1446, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/1
current outbound spi: 0x3233EF(3290095)
PFS (Y/N): Y, DH group: group2
inbound esp sas:
spi: 0xAB177A98(2870442648)
transform: esp-3des esp-sha-hmac ,
in use settings ={Tunnel, }
conn id: 2001, flow_id: Onboard VPN:1, sibling_flags 80000040, crypto map: ToReseau2
sa timing: remaining key lifetime (k/sec): (4157029/3117)
IV size: 8 bytes
replay detection support: Y
Status: ACTIVE(ACTIVE)
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 2002, flow_id: Onboard VPN:2, sibling_flags 80000040, crypto map: ToReseau2
sa timing: remaining key lifetime (k/sec): (4157030/3117)
IV size: 8 bytes
outbound ah sas:
outbound pcp sas:
GoMobile3616#
Please see the cisco 1921.pdf file for the show tech-support command.
Thank You again to take time to helping me.
Patrick Lussier
OrizonMobile
So you are not able to reach from the laptop behind the Cisco router to the Cisco router itself?
Please give me the output of show IP route from the Cisco router.
Do a traceroute from the laptop for the netgear router and give me the results. Next do traceroute for the Cisco router from the laptop and paste it hear.
Thanks!
For the Laptop (192.168.116.101) connected on the Cisco Router (192.168.116.1), it can reach it, the ping is working.
Please see the attached .pdf file for the network schematic.
What append is that the VPN tunnel look like to be established but no data pass through it.
Please see the word file for the Trace Route.
here is the
GoMobile3616#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override
Gateway of last resort is 192.168.20.1 to network 0.0.0.0
S*    0.0.0.0/0 [254/0] via 192.168.20.1
      192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.20.0/24 is directly connected, GigabitEthernet0/1
L        192.168.20.100/32 is directly connected, GigabitEthernet0/1
      192.168.116.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.116.0/24 is directly connected, Vlan1
L        192.168.116.1/32 is directly connected, Vlan1
    #pkts decaps: 291, #pkts decrypt: 291, #pkts verify: 291
     local crypto endpt.: 192.168.20.100, remote crypto endpt.: xxx.xxx.xxx.xxx
     current outbound spi: 0x758FCFD(123272445)
     inbound esp sas:
      spi: 0xE49DD805(3835549701)
        conn id: 2003, flow_id: Onboard VPN:3, sibling_flags 80000040, crypto map: ToReseau2
        sa timing: remaining key lifetime (k/sec): (4209713/2243)
        IV size: 8 bytes
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 2004, flow_id: Onboard VPN:4, sibling_flags 80000040, crypto map: ToReseau2
        IV size: 8 bytes
     outbound ah sas:
     outbound pcp sas:
GoMobile3616#
Make it this way:
Thanks!
I did the modification and now the trafic is able to pass in the VPN tunnel  between Cisco1921 and Netgear fvx538.
 #pkts encaps: 661, #pkts encrypt: 661, #pkts digest: 661
    #pkts decaps: 666, #pkts decrypt: 666, #pkts verify: 666
Thank You very much for your time.
Have a good day !
Can we setup more than one Site-ToSite VPN on the Cisco 1921 ?
I tried to setup a second one but it conflict with the first one.
when i applied the crypto map Test to the same interface GE0/1 it do nothnig and the other VPN to the 192.168.2.0 network goes down ?
Do you have some documents about how to configure multiple site-to-site VPN.
I need to setup 15 Site-To-Site VPN between the Cisco 1921 and 15 Netgear FVX538 on different site.
Thank You !
Hi Plussier,
I think what you have done is you have created a new crypto map and applied it on the same interface.
You do not have to do that otherwise it will over-write the first one.  You cannot have multiple crypto maps applied on a single interface.
Just create multiple entries in the same crypto map.
Example: crypto map 1 test match address <name>
                crypto map 1 test set peer q.q.q.q
                 crypto map 1 test set transform set <name>
                  crypto map 2 test match address <name>
                   crypto map 2 test set peer t.t.t.t
                   crypto map 2 test set transform set <name>
So here would be two tunnel on the same box forming tunnels with two differnet peers. And you just apply the crypto map "test" on the interface.
  Hope this helps!
Thanks!
Moved post to Network Infrastructure Community.
Hi Glen,
I tried what jumukhi wrote bellow but I can't add number before the name test.
Please see my complete Site-To-Site tunnel command on attached files.
I need to have around 16 Site-To-Site VPN between my CISCO 1921 with the same interface.
I tried that but the router can't accept the number in red.
Please let my know what I need to do to add more than one site-to-site VPN on the same Interface.
Thank You !
Patrick
jumukhi 12 days ago
Hi Plussier,
  Hope this helps!
Thanks!
Thanks!
I Tested That and it is worked now.
Thank You and have a Good day !
If I have other question on different subject, can I continue to Write on this Discussion or it is better to Start a new One ?
Patrick Lussier
