Trying to configure 2821 Router for use at home.
BBadalamente
I hope I am posting in the correct category, I apologize if it isn't.
I have purchased a 2821 router to screw around with at home so I can become more familiar with the IOS CLI. However, I cannot seem to figure why NAT is not working. Every NAT translation expires.
G0/0 is set to DHCP to receive an IP from my ISP.
G0/1 is the default gateway for my LAN
Nat statement
"ip nat inside source list NAT interface GigabitEthernet0/0 overload"
NAT ACL is "permit 0.0.0.0 0.0.0.0"
Any help would be greatly appreciated, I am kind of disappointed that I can not figure this out myself :/
Here is the rest of the configuration.
Current configuration : 1380 bytes
version 12.4
hostname Home
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp pool LAN
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 8.8.8.8
ip domain name PCMasterRace
ip name-server 8.8.8.8
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
voice-card 0
 no dspfarm
 ip address dhcp
 ip nat outside
 ip virtual-reassembly
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip nat inside
 duplex auto
 speed auto
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip http server
no ip http secure-server
ip access-list standard NAT
 permit 0.0.0.0
control-plane
line con 0
 logging synchronous
line aux 0
line vty 0 4
 logging synchronous
 login local
 transport input ssh
line vty 5 15
 logging synchronous
 login local
 transport input ssh
scheduler allocate 20000 1000
end
hi,
could you post a brief network diagram? is there a modem/router before your 2821?
could you try:
no ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip route 0.0.0.0 0.0.0 dhcp
I have also tried pinging 8.8.8.8 but keep getting timed out - See more at: https://supportforums.cisco.com/discussion/12492651/trying-configure-2821-router-use-home#sthash.0iZUtG8g.dpuf
9 Replies 9
johnlloyd_13
Level 9
Level 9
hi,
could you post a show ip interface brief and ping output to 8.8.8.8 from your 2821?
try to re-configure your NAT ACL as below:
no ip access-list standard NAT
no ip nat inside source list NAT interface GigabitEthernet0/0 overload
access-list 10 permit 192.168.2.0 0.0.0.255
ip nat inside source list 10 interface GigabitEthernet0/0 overload
Thank you for response, I have already tried using an ACL as  specified. I tried using quad zeros when I saw that it was not working. I will try again as you are suggesting. Would a quad zero statement work in this case?
I have tried using show ip int brief and have verified that G0/0 has received an address from my modem. I am able to ping the address from both my host and router.
I have also tried pinging 8.8.8.8 but keep getting timed out. I have noticed that when I use `show ip Nat translations` both the outside local and global appear as 8.8.8.8 . I am unsure if that is normal or not. Nat is still a new concept to me.
Unfortunately, I am very busy at the moment so it may be a bit before I can test and report back.
hi,
could you try:
Worked thank you very much! This is the first time I am hearing about DHCP being used as the next hop/exit interface. I am already glad I bought this router and I have already learned something!
I know this thread is two years old.
But I have this line in my config
And I was just hoping to get an understanding of what that means.
Actually I have this config file that is full of commands I don't really understand.
I guess I could read a reference, but I was just hoping someone could look at it and explain it to me.
m.rana.ku
I am sharing a great content which will demonstrate step by step process of Connecting Cisco 2851 Router and Cisco 3560 Switch to ISP Home router and Configuring Cisco Router using Putty and finally Accessing Internet from Laptop and Desktop PC through this network.
PuTTY command line for Router Configuration:
Where hostname of the Router is "Router"
Entering to Privileged mode:
Router>enable
Check IP Interface:
Router#show ip interface brief
Entering to Global Configuration mode:
Router#configure terminal
Entering GE0/0 Interface:
Router(config)#interface gigabitEthernet 0/0
Making Interface up:
Router(config-if)#no shutdown
Assigning IP address from DHCP:
Router(config-if)# ip address dhcp
Ping to Google DNS server:
Router#ping 8.8.8.8
Entering GE0/1 Interface:
Router(config)#interface gigabitEthernet 0/1
Assigning IP address :
Router(config-if)#ip address 192.168.2.1 255.255.255.0
Creating DHCP pool:
First go to global configuration mode then
Router(config)#ip dhcp pool mainuser
Router(dhcp-config)#network 192.168.2.0 /24
Router(dhcp-config)#default-router 192.168.2.1
Router(dhcp-config)#dns-server 8.8.8.8
Router(dhcp-config)#exit
Static Routing for default Gateway
Router(config)#ip route 0.0.0.0 0.0.0.0 192.168.1.1
Configuring NAT Outside:
Router(config-if)#ip nat outside
Router(config-if)#exit
Configuring NAT inside:
Router(config-if)#ip nat inside
Creating Access list:
Router(config)#ip access-list standard 1
Router(config-std-nacl)#permit any
Router(config-std-nacl)#exit
Overloading IP NAT inside source to the interface gigabitEthernet 0/0:
Router(config)#ip nat inside source list 1 interface gigabitEthernet 0/0 overload
https://www.youtube.com/channel/UCmZZ2BNGXQH1HPS3uIVnr7A?sub_confirmation=1
