Trying to ping from vlan to default gateway with no success.
Roberto Soto
Hello, in my home lab, I have a Cisco 871W named cants. I connected cants to my BT (ISP) router (BT.homeblahblah) using the wan link f 4, then I created a vlan 2 and assign it to por f1 on the 871 router. Im unable to ping from that vlan to router 192.168.1.254 which is my bt router.
Please see my config file:
Building configuration...
Current configuration : 1845 bytes
version 12.4
no service pad
service password-encryption
hostname cants
boot-start-marker
boot-end-marker
enable secret 5
no aaa new-model
dot11 syslog
ip cef
no ip domain lookup
ip domain name canterburyhub.local
no spanning-tree vlan 1
no spanning-tree vlan 2
username
username
archive
log config
  hidekeys
ip ssh version 2
interface FastEthernet0
interface FastEthernet1
switchport access vlan 2
interface FastEthernet2
switchport mode trunk
interface FastEthernet3
interface FastEthernet4
description INTRANET ROUTER CONNECTION
ip address 192.168.1.253 255.255.255.0
ip access-group 100 in
speed 100
full-duplex
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
ip address 172.16.0.1 255.255.0.0
interface Vlan2
ip address 172.18.0.1 255.255.0.0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.1.254
ip route 192.168.1.0 255.255.255.0 192.168.1.254
no ip http server
no ip http secure-server
access-list 100 permit ip any any
access-list 101 permit ip any any
control-plane
banner motd ^CC
DO NOT LOG ON
^C
line con 0
password 7 12290446431C5C162E
logging synchronous
login
no modem enable
line aux 0
login
line vty 0 4
logging synchronous
login local
transport input ssh
scheduler max-task-time 5000
end
cants#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 192.168.1.254 to network 0.0.0.0
C    172.18.0.0/16 is directly connected, Vlan2
C    192.168.1.0/24 is directly connected, FastEthernet4
S*   0.0.0.0/0 [1/0] via 192.168.1.254
cants#sh ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
Dot11Radio0                unassigned      YES NVRAM  administratively down down
FastEthernet0              unassigned      YES unset  down                  down
FastEthernet1              unassigned      YES unset  up                    up
FastEthernet2              unassigned      YES unset  up                    down
FastEthernet3              unassigned      YES unset  up                    down
FastEthernet4              192.168.1.253   YES NVRAM  up                    up
Vlan1                      172.16.0.1      YES NVRAM  up                    down
Vlan2                      172.18.0.1      YES NVRAM  up                    up
Now when I try to ping from a laptop connected using a cable to f 1 I get request timed out. Also when I try to pring from the router, nothing:
cants#ping 192.168.1.254 source 172.18.0.1
Sending 5, 100-byte ICMP Echos to 192.168.1.254, timeout is 2 seconds:
Packet sent with a source address of 172.18.0.1
Success rate is 0 percent (0/5)
I hope I have given enough information, but please let me know if you need more. I understand the the basics how vlan advertise themselves, I understand the basics of routing, thats why I created 192.168.1.254 (BT router) as my last resort default gateway, so that everything can go there if no other route given.
Many thanks in advance.
Jon Marshall
The BT router does not know how to get to that subnet.
So you have two options -
1) add a route to the BT router. Don't know the syntax for that but in IOS it would be -
ip route 172.18.0.0 255.255.0.0 192.168.1.253
2) if you can't add a route to the BT router then you can NAT all your 172.18.x.x addresses to 192.168.1.253 because your BT router knows how to get to that so on your router -
int vlan 2
ip nat inside
int fa4
ip nat outside
access-list 101 permit ip 172.18.0.0 0.0.255.255 any
ip nat inside source list 101 interface fa4 overload
Jon
Hello Jon,
Many thanks for your reply. I thought about what you has just replied which I appreciated because reassure me. I figured out with your reply where I failed. When I tracert from a windows machine on vlan 2 (172.18.0.2) to 192.168.1.254 I saw that it stopped on 172.18.0.1, so I thought I must be missing something because Im not getting a reply from .253, but I guess now that 192.168.1.253 its not on route, so therefore the next hop is 192.168.1.254 which is on my route table.
Again, thank you very much for your time and reply.
