TTL differnt value in ping
when i ping yahoo.com i get reply with a differnt TTL, i want an explanation for that problem....
Thank you for your help
Ahmed Tantawy
N.B.,a snapshot to the ping is attached.
mohammedmahmoud
Level 11
Level 11
This means that for some reason the 3rd and 4th packets took a different path with less routers in it (TTL is reduced by one when passing through a router).
HTH, please rate if it does help,
Mohammed Mahmoud.
Thanks for your respond but i ask for the reason uopn which this case occured.....it makes me crazy thinking of it.
Thank you
As far as i can say, the TTL value in the received packet will be 255 minus the number of routers in the round-trip path. The 3rd and 4th packets have found another path on the internet while traveling to/from the destination and thus they took it.
HTH,
Mohammed Mahmoud.
