EIGRP W DEFAULT-ROUTE
alsayed
i have seen config like this:
DS1
router EIGP1
network 100.100.0.0 0.0.255.255
network 192.168.100.18 0.0.0.3
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.100.17(CORE SIDE)
Why they config the default route?however eigrp is runing
regards
mohammedmahmoud
Level 11
Level 11
Hi there,
This configuration means that in the case of no match in the routing table (populated with either EIGRP or static routes) the default route is used having the next hope 192.168.100.17(CORE SIDE), there is no problem by doing this as a Gateway of last resort.
HTH, please rate if it does help,
Mohammed Mahmoud.
Hi 10xs for ur reply
mahmoodmkl
Level 7
Level 7
Ali
As mahmoud suggested the u r DS1 will be going to farword the traffic it it doesnt matches any routes in u r routing table to 192.168.100.17.this is the gateway of last resort.
Mahmood
