Tunnel Interface /32 Host Mask
johnlloyd_13
Level 9
Level 9
hi all,
first, i would like to greet everyone a prosperous 2013!
i'm currently doing GRE tunneling between 2 routers and would like to use a /32 host mask, but was rejected. is this an IOS restriction?
R1(config-if)#tunnel destination 192.168.0.2
R1(config-if)#ip address 10.0.0.1 255.255.255.255
Bad mask /32 for address 10.0.0.1
R1(config-if)#ip address 10.0.0.1 255.255.255.254
R1(config-if)# do sh run int tu0
Building configuration...
Current configuration : 121 bytes
interface Tunnel0
tunnel source 192.168.0.1
end
Nagendra Kumar Nainar
Hi John,
You cannot directly configure a /32 address on tunnel (or other physical interface). You need to configure it on a loopback interface and assign it as "ip unnumbered loop<>" under tunnel interface as below,
interface Loopback3
ip address 10.3.3.3 255.255.255.255
interface Tunnel3
ip unnumbered Loopback3
HTH,
Nagendra
Hi John,
interface Loopback3
interface Tunnel3
HTH,
Nagendra
hi nagendra,
thanks for the quick reply! do you have a useful link with this info?
Hardik Vaidh
Dear john
you cannt configure any ip directly in your tunnel or any where related to interface matter.
you have to configure interface lokback 0
ip add 10.10.10.10 255.255.255.255
no shut
show ip int brie
lookback up
then you can configure any whare 10.10.10.10 255.255.255.255
subnet 255.255.255.255 means host
please help me when i am configuring  the R2(config)#int Fa0/1
ip address 3.3.3.3 255.255.255.255
i am getting the Bad mask /32 for address 3.3.3.3
