Tunnel is Active but host stop pinging randomly.
Amardeep Kumar
I have P2P tunnel between Cisco asa. it is working perfectly for years but some time host stop pinging randomly.
clear crypto isakmp sa
Please suggest.
Amardeep
hard to tell without seeing the configs. Do you have isakmp keepalives configured, e.g.:
ASA(config)# tunnel-group xxx.xxx.xxx.xxx ipsec-attributes
ASA(config-tunnel-ipsec)# isakmp keepalive threshold 15 retry 10
5 Replies 5
Yes , I have this setting. Just decrease timing  from 30 to 15.
Other Suggestion please
Amardeep
Can you share the result of the command show crypto ipsec sa?
Crypto map tag: outside_map, seq num: 1, local addr: x.x.x.x
access-list outside_cryptomap_4 extended permit ip 192.168.3.0 255.255.255.0 192.168.12.0 255.255.252.0
local ident (addr/mask/prot/port): (192.168.3.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (192.168.12.0/255.255.252.0/0/0)
current_peer: y.y.y.y
#pkts encaps: 88124543, #pkts encrypt: 88123686, #pkts digest: 88123686
#pkts decaps: 2117527, #pkts decrypt: 2117507, #pkts verify: 2117507
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 88124543, #pkts comp failed: 0, #pkts decomp failed: 0
#pre-frag successes: 0, #pre-frag failures: 857, #fragments created: 0
#PMTUs sent: 857, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
#TFC rcvd: 0, #TFC sent: 0
#Valid ICMP Errors rcvd: 0, #Invalid ICMP Errors rcvd: 0
#send errors: 0, #recv errors: 23
local crypto endpt.: x.x.x.x/0, remote crypto endpt.: y.y.y.y/0
path mtu 1500, ipsec overhead 58(36), media mtu 1500
PMTU time remaining (sec): 0, DF policy: copy-df
ICMP error validation: disabled, TFC packets: disabled
current outbound spi: 567DA260
current inbound spi : CF564B6F
inbound esp sas:
spi: 0xCF564B6F (3478539119)
SA State: active
transform: esp-3des esp-md5-hmac no compression
in use settings ={L2L, Tunnel, PFS Group 2, IKEv1, }
slot: 0, conn_id: 134795264, crypto-map: outside_map
sa timing: remaining key lifetime (kB/sec): (3642054/25510)
IV size: 8 bytes
replay detection support: Y
Anti replay bitmap:
0xFFFFFFFF 0xFFFFFFFF
outbound esp sas:
spi: 0x567DA260 (1451074144)
SA State: active
IV size: 8 bytes
Anti replay bitmap:
outbound esp sas:
SA State: active
sa timing: remaining key lifetime (kB/sec): (1047800/25484)
IV size: 8 bytes
Anti replay bitmap:
0x00000000 0x00000001
Again - it is Active but some time stops itself.
thanks
amardeep
Hi again,
You have packet mtu fragmentation problem
#PMTUs sent: 857
DF policy: copy-df
Try this command "crypto ipsec df-bit clear-df", in the link below you can find detailed explanation
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_conn_dplane/configuration/15-mt/sec-ipsec-data-plane-15-mt-book/sec-df-bit-ovride.html
