Can't send and receive encrypted multicast traffic over tunnel over internet on two Cisco 861 series!
FayezIllariyeh
I have two Cisco 861 in different places connected to internet with fixed public IP, i wanna to make an encrypted tunnel between two routers to send and receive multicast traffic, knowing there's ping succeeded between 192.168.3.0 and 192.168.1.0, but can't send or receive multicast traffic! and can't apply 'ip multicast-routing' command. Below the configuration on routers :
#show ver
Cisco IOS Software, C860 Software (C860-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 10
ip source-route
ip cef
crypto isakmp policy 10
 encr aes 256
 authentication pre-share
 group 5
crypto isakmp key secretkey address y.y.y.2
crypto ipsec transform-set R1-R2 esp-aes 256 esp-sha-hmac
crypto map IPSEC-MAP 10 ipsec-isakmp
 set peer y.y.y.2
 set security-association lifetime seconds 86400
 set transform-set R1-R2
 set pfs group5
 match address 100
interface FastEthernet0
 switchport access vlan 300
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
 ip address x.x.x.2 255.255.255.252
 duplex auto
 speed auto
interface Vlan1
 no ip address
interface Vlan300
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 x.x.x.1
access-list 100 permit ip 192.168.1.0 0.0.0.255 192.168.3.0 0.0.0.255
control-plane
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
scheduler max-task-time 5000
end
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
license accept end user agreement
encr aes 256
group 5
crypto isakmp key secretkey address x.x.x.2
crypto ipsec transform-set R2-R1 esp-aes 256 esp-sha-hmac
set peer x.x.x.2
set transform-set R2-R1
set pfs group5
match address 100
switchport access vlan 301
no ip address
no ip address
no ip address
no ip address
ip address y.y.y.2 255.255.255.252
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan301
ip address 192.168.3.1 255.255.255.0
no ip http server
ip route 0.0.0.0 0.0.0.0 y.y.y.1
access-list 100 permit ip 192.168.3.0 0.0.0.255 192.168.1.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
login
transport input all
end
the Cisco 861 may be not so new I'm afraid.
Likely you need more modern routers that support multicast.
see Cisco 890 series datasheet
  IPv4 and IPv6 Multicast
https://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/data_sheet_c78-519930.html
Hope to help
Giuseppe
6 Replies 6
guibarati
Level 4
Level 4
I don't think you'll be able to send multicast traffic across the cryptomap VPN. You're better off using a tunnel interface with an IPSec profile, then you can establish multicast routing - if your router supports multicast.
Giuseppe Larosa
Hello ,
this is a known limitation of IPSec
to carry multicast traffic you need to use a GRE point to point tunnel that provides a way to transport any type of traffic.
You can still use the crypto map but you are going to encrypt the GRE tunnel packets
access-list 111 remark GRE packets
access-list 111 permit gre host <local-address> host <remote-address>
interface tunnel 1
tunnel source interface
tunnel destination <remote-ip-address>
ip address 10.10.12.1 255.255.255.252
ip pim sparse-dense mode
no shut
You may need on the receiving side an ip mroute static to pass the RPF check
ip mroute 0.0.0.0. 0.0.0.0 tunnel1
Hope to help
Giuseppe
Thanks for your reply,
I can't do ip pim sparse-dense mode command inside tunnel!, and if i do show ip multicast, the status is disabled, how can i enable multicast routing ? Are this routers and their versions together support multicast routing and PIM protocol?
Thanks in advance,
you need to enable at global level with
config t
after that you should be able to use the PIM commands if your router supports multicast routing
NOTE:
you will need to enable PIM also on the internal LAN interface
do not enable PIM on the WAN interface (the one used as tunnel source in GRE tunnel).
You need also some unicast routing for the subnets
like
ip route 192.168.100.0 255.255.255.0 tunnel0
to route ove the tunnel the traffic of internal LAN subnets.
Hope to help
Giuseppe
It seems that doesn't support multicast routing! Do you have an advice to pass this issue? like upgrade the IOS or need another series router?
Hope to help
Giuseppe
