Tunnel is not established
msasikumar
Hi All,
I am very new for tunnels. And, i am seeing one of the router tunnel 2 is not established.Pls inform what are the things need to be checked if it's not established.
i have mentioned details below.
interface Tunnel2
description Internet Tunnel
ip address 10.X.X.33 255.255.254.0
no ip redirects
ip mtu 1416
ip flow egress
ip nhrp authentication cisco
ip nhrp map multicast dynamic
ip nhrp map 10.214.243.254 146.197.246.22
ip nhrp map multicast 146.197.246.22
ip nhrp network-id 2
ip nhrp holdtime 300
ip nhrp nhs 10.214.243.254
ip nhrp cache non-authoritative
zone-member security STORE_NWSC
delay 1000
cdp enable
tunnel source FastEthernet0/1
tunnel mode gre multipoint
tunnel key 2
tunnel protection ipsec profile VT2 shared
router eigrp 1
passive-interface Vlan20
network 10.146.22.0 0.0.0.255
network 10.212.32.64 0.0.0.63
network 10.212.32.128 0.0.0.63
network 10.214.240.0 0.0.1.255
network 10.214.242.0 0.0.1.255
no auto-summary
eigrp stub connected summary
ip route 10.146.2.48 255.255.255.255 Vlan20
ip route 146.197.238.26 255.255.255.255 Vlan20
ip route 146.197.246.22 255.255.255.255 FastEthernet0/1 dhcp
IP-EIGRP neighbors for process 1
H   Address                 Interface       Hold Uptime   SRTT   RTO  Q  Seq
                                            (sec)         (ms)       Cnt Num
0   10.214.241.254          Tu1               12 01:06:18 4260  5000  0  1541045
FastEthernet0/1 is up, line protocol is up
  Hardware is Gt96k FE, address is 0021.d8fe.08f7 (bia 0021.d8fe.08f7)
  Description: This interface to be configured for DHCP from DSL Carrier
  Internet address is 68.188.126.76/25
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 01:22:01, output 00:00:04, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     217751 packets output, 22567940 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
     0 lost carrier, 0 no carrier
6 Replies 6
Ivan Krimmel
Level 7
Level 7
I can't see 'tunnel destination' being configured.
Ivan.
Hi Ivan,
The missing tunnel destination command is logical - this is a multipoint GRE tunnel with endpoints being discovered/mapped using NHRP. Configuring the destination statically would not be even accepted by the IOS.
I would be very interested in knowing if it is possible to ping at least the IP addresses 146.197.246.22 and 10.214.243.254. Also, the output of show ip nhrp tun2 detail command would be illustrative.
Best regards,
Peter
oh ya, missed those *nhrp* lines, sorry.
Ivan,
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Besides checking whether you can ping between public IPs, you might also double check ALL crypo and tunnel parameters agree between the hub and the spoke.
Joseph,
What's with the disclaimer? This is just a forum where people offer help and answers to questions. Your not prescribing medicine. Is there really a need for that and the space it takes up?
Disclaimer
Posting
Well, if Cisco requires us to indemnify them and release them from all liabilities as part of their User Agreement, rather be safe than sorry.
