Tunnel Recursive Routing over EZVPN (Removed)
K-Grev
Discussion removed. Solution not pertinent to issue.
Thanks for time and assistance.
Don't know how to delete thread
17 Replies 17
Sir,
Thank you for the reply, I really appreciate it. Can you tell me how
exactly I would do this and would I do it on the 4500X?
I was trying to do a route map to stop advertising the tunnel destination
this morning but I wasn't doing it correctly as the recursive routing still
happens.
I have only had to do a route map once so I have very little experience
with it.
I really appreciate all the helpful suggestions.
K-Grev
(Removed)
K-Grev
problem of not pinging seems changed. I can ping loopback to loopback but I cannot source from other interfaces.
While G2.10 is up on the LTE Router
