PPPoE on C881-K9 failing
DON BROWN
I have IOS version 157-3.M7 on C881 Router
Trying to connect PPPoE to ISP
Relevant Config ...
vpdn enable
vpdn-group 1
interface FastEthernet4
description NBN Connection to Internet
no ip address
ip nbar protocol-discovery
ip nat outside
ip virtual-reassembly in
duplex full
speed 100
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp pap sent-username @redacted>@redacted.com.au password 0 <password>
ip nat inside source list 22 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet4
dialer-list 1 protocol ip permit
I have the following debugs active
PPP:
PPP authentication debugging is on
PPP protocol negotiation debugging is on
PPPoE:
PPPoE protocol events debugging is on
The debug is showing;
036361: *Sep 21 22:00:44.365: Sending PADI: Interface = FastEthernet4
036362: *Sep 21 22:00:56.429: PPPoE 0: I PADI R:2247.3292.89ee L:ffff.ffff.ffff Fa4
036363: *Sep 21 22:01:01.433: PPPoE 0: I PADI R:2247.3292.89ee L:ffff.ffff.ffff Fa4
036364: *Sep 21 22:01:11.445: PPPoE 0: I PADI R:2247.3292.89ee L:ffff.ffff.ffff Fa4
036365: *Sep 21 22:01:16.621: padi timer expired
PPPoE Session is not established
sh pppoe sess
1 client session
Uniq ID PPPoE RemMAC Port VT VA State
SID LocMAC VA-st Type
N/A 0 0000.0000.0000 Fa4 Di1 N/A PADISNT
0000.0000.0000
So no ip address has been negotiated on the dialer interface.
I have been going in circles with this for hours - what am I missing please.
you need to use Dialer 1 as the outgoing interface. Configure the settings below (Vlan 1 IP address is assumed since you did not post your full config, make sure access list 1 matches whatever IP address space you are using on Vlan 1):
vpdn enable
vpdn-group 1
no ip address
ip nat outside
duplex full
speed 100
interface Dialer1
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
interface Vlan1
ip nat inside
ip nat inside source list 1 Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit 192.168.1.0 0.0.0.255
Thank you for your suggestions - I have applied the changes you suggested but still am not getting PPPoE session established.
Please find current config below.
vpdn enable
vpdn-group 1
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
no ip address
ip nat outside
duplex full
speed 100
interface Vlan1
description $ETH_LAN$
ip address 10.1.1.77 255.255.255.0
ip nat inside
interface Dialer1
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp pap sent-username <redacted> password 0 <redacted>
ip nat inside source list 22 interface Dialer1 overload
ip ssh version 2
access-list 22 permit 10.1.1.0 0.0.0.255
access-list 23 permit 10.1.1.0 0.0.0.255
Debug logs
040116: *Sep 22 06:52:31.615: padi timer expired
040117: *Sep 22 06:52:31.615: Sending PADI: Interface = FastEthernet4
040118: *Sep 22 06:52:53.607: PPPoE 0: I PADI R:2247.3292.89ee L:ffff.ffff.ffff Fa4
040119: *Sep 22 06:52:58.611: PPPoE 0: I PADI R:2247.3292.89ee L:ffff.ffff.ffff Fa4
040120: *Sep 22 06:53:03.871: padi timer expired
040121: *Sep 22 06:53:03.871: Sending PADI: Interface = FastEthernet4
040122: *Sep 22 06:53:08.619: PPPoE 0: I PADI R:2247.3292.89ee L:ffff.ffff.ffff Fa4
040123: *Sep 22 06:53:36.126: padi timer expired
040124: *Sep 22 06:53:36.126: Sending PADI: Interface = FastEthernet4
Still no IP address negotiated for D1
Dialer1 unassigned YES NVRAM up up
FastEthernet0 unassigned YES unset down down
FastEthernet1 unassigned YES unset down down
FastEthernet2 unassigned YES unset down down
FastEthernet3 unassigned YES unset up up
FastEthernet4 unassigned YES NVRAM up up
NVI0 unassigned YES unset up up
Virtual-Access1 unassigned YES unset up up
Vlan1 10.1.1.77 YES NVRAM up up
I have looked around, it is possible that you need a subinterface. Make the changes marked in bold:
vpdn enable
vpdn-group 1
no ip address
no ip address
no ip address
no ip address
no ip address
duplex auto
speed auto
interface FastEthernet4.2
encapsulation dot1q 2
interface Vlan1
ip nat inside
interface Vlan2
description --- NBN Logical Interface ---
bandwidth 20000
bandwidth receive 50000
no ip address
ip mtu 1460
ip nat outside
interface Dialer1
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ip ssh version 2
Thank you for your suggestion.
When I first looked at the suggestions I did not think it would work but there have been many times something I did not think would work actually did so I made the changes.
Situation is still the same
Debug shows
040905: *Sep 22 08:44:35.365: padi timer expired
040906: *Sep 22 08:44:35.365: Sending PADI: Interface = FastEthernet4.2
040907: *Sep 22 08:44:35.365: PPPoE VLAN CoS (pppoe_client_send_padi)=>FastEthernet4.2 :: cos=0x0
040908: *Sep 22 08:45:07.624: padi timer expired
040909: *Sep 22 08:45:07.624: Sending PADI: Interface = FastEthernet4.2
040910: *Sep 22 08:45:07.624: PPPoE VLAN CoS (pppoe_client_send_padi)=>FastEthernet4.2 :: cos=0x0
040911: *Sep 22 08:45:39.880: padi timer expired
040912: *Sep 22 08:45:39.880: Sending PADI: Interface = FastEthernet4.2
040913: *Sep 22 08:45:39.880: PPPoE VLAN CoS (pppoe_client_send_padi)=>FastEthernet4.2 :: cos=0x0
040914: *Sep 22 08:46:12.136: padi timer expired
040915: *Sep 22 08:46:12.136: Sending PADI: Interface = FastEthernet4.2
040916: *Sep 22 08:46:12.136: PPPoE VLAN CoS (pppoe_client_send_padi)=>FastEthernet4.2 :: cos=0x0
040917: *Sep 22 08:46:44.403: padi timer expired
040918: *Sep 22 08:46:44.403: Sending PADI: Interface = FastEthernet4.2
040919: *Sep 22 08:46:44.403: PPPoE VLAN CoS (pppoe_client_send_padi)=>FastEthernet4.2 :: cos=0x0
040920: *Sep 22 08:47:16.659: padi timer expired
Still no ip address being assigned to dialer interface
Please advise
