tunnel source dynamic command
daleschultz
Hi:
The command documenation is very limited:
http://www.cisco.com/en/US/docs/ios-xml/ios/interface/command/ir-t2.html#wp1398569350
Can someone explain what this command is really supposed to do?
If I set it on the Tunnel interface which has a known destination I get a value of UNKNOWN for the Tunnel source.
I would like the Tunnel source to be dynamic in that the IOS chooses the IP address from the UP interface used in the path (route) to the destination, i.e.: outbound interface.
Thanks for any insight.
Current configuration : 489 bytes
interface Tunnel0
ip address 192.168.66.196 255.255.255.192
no ip redirects
ip mtu 1400
ip pim sparse-dense-mode
ip nhrp authentication XYZ
ip nhrp group XYZ_QOS
ip nhrp map multicast 172.31.31.31
ip nhrp map 192.168.66.193 172.31.31.31
ip nhrp network-id 111
ip nhrp holdtime 180
ip nhrp nhs 192.168.66.193
ip tcp adjust-mss 1360
qos pre-classify
tunnel destination 172.31.31.31
tunnel key 100111
tunnel protection ipsec profile XYZ
end
TESTRTR#sh int t0
Tunnel0 is up, line protocol is down
  Hardware is Tunnel
  Internet address is 192.168.66.196/26
  MTU 17912 bytes, BW 100 Kbit/sec, DLY 50000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source UNKNOWN, destination 172.31.31.31
  Tunnel protocol/transport GRE/IP
    Key 0x1870F, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255, Fast tunneling enabled
  Tunnel transport MTU 1472 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Tunnel protection via IPSec (profile "XYZ")
  Last input never, output 00:30:59, output hang never
  Last clearing of "show interface" counters 00:58:18
  Queueing strategy: fifo (QOS pre-classification)
  Output queue: 0/0 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
5 Replies 5
daleschultz
Did I ask in the wrong forum maybe?
The only place I've seen "tunnel source dynamic" referenced is for IKEv2.  Maybe there are other uses, but in the IKEv2 example you'd use:
crypto ikev2 client flexvpn CRYPTO-IKEV2-CLIENT
  source 1 GigabitEthernet8 track 1
  source 2 GigabitEthernet9 track 2
  client connect Tunnel1
interface Tunnel1
rais
Level 7
Level 7
For a tunnel you are supposed to supply the two terminating end points. Using dynamic will not require you to configure the source address. You can connect to Internet anyways [may be with a dynamic IP address], the tunnel will be created. Pretty much what you have already stated.
HTH.
Yes that's what I would expect to happen, but it does not in practice.  So the qusetion remains, how and when is this command supposed to be used.
Can you add 'tunnel mode gre multi'
Thanks.
