06-02-2024 03:01 AM
I have general question not specific to one brand like cisco etc.
I have 2 pc one with internet access and second one not have internet access.
Anyone knpw what tools can be used for redirect or tunnel the traffic from 2nd pc whic not have internet access via 1st pc? I found some tools but this is work for browser by change the proxy. But if i have desktop application, the tools is not working.
06-02-2024 04:10 AM
Any VPN have
Client and server (GW)
Here you have two PC i.e. two clients so there is no vpn for this case
MHM
06-02-2024 04:21 AM
Current two PCs can communicate each other becuase on same LAN. So i need to creat VPN and access the VPN using lan connection, right?
06-02-2024 04:26 AM
If one device connect to device like SW or router can work as VPN GW then you can use l2tp vpn make PC (in internet) appear as it direct connect to same LAN of internal PC.
You need GW for this VPN
MHM
06-02-2024 08:33 AM
Hello
you do t mention what the pcs operating systems are but most vendors allow to share their internet connection - in windows it’s called ICS internet-connection sharing
Based on you OP it seems this would be the most simplistic option for you
06-02-2024 08:41 AM
Hi..
Both PC running under windows 10. ICS as i know this is for sharing connectiion across network card on same machine, how ICS can share the connection to otjer PC in same LAN?
06-02-2024 08:46 AM
Both pcs are connected to the same lan correct - if so they share each others internet connection
06-02-2024 06:23 PM
06-03-2024 12:56 AM
Hello
Looking at the topology you've have posted ,I would confirm you would not need any VPN or ICS.
PC2 is routing via the CORE and FW, with the assumption the FW is performing NAT, so what is negating you from allowing PC1 the same access, Surely it would just be a matter of appending PC1 details to any exiting FW rule base and nat acls that allowing PC2?
06-03-2024 12:59 AM
Hi..
unfortunately we not have access to the firewall, so need other way.
06-03-2024 03:22 AM
Hello
Unfortunately thats where you probably need to allow the access, unless its being allowed on the core - can you share the configuration of the core switch (attached it to a file)
