Tunnel went DOWN, the fragment table has reached its maximum threshold
JonRedn11
Hi everyone,
Suddenly, my tunnels Cisco-Cisco stopped working and I'm getting those messages:
*Dec 15 2023 20:41:52.180: %DMVPN-5-NHRP_CACHE: Client 192.xxx.xx.xxx on Tunnel went DOWN.
*Dec 15 2023 20:42:10.352: %IP_VFR-4-FRAG_TABLE_OVERFLOW: GigabitEthernet0/0.102: the fragment table has reached its maximum threshold 16
*Dec 15 2023 20:42:35.201: %DMVPN-3-NHRP_ERROR: Resolution Request failed for 0.0.0.0 on Tunnel
*Dec 15 2023 20:42:41.305: %IP_VFR-4-FRAG_TABLE_OVERFLOW: GigabitEthernet0/1.300: the fragment table has reached its maximum threshold 16
*Dec 15 2023 20:43:11.329: %IP_VFR-4-FRAG_TABLE_OVERFLOW: GigabitEthernet0/0.102: the fragment table has reached its maximum threshold 16
I executed the command virtual-reassembly <max-reassemblies> according some comments but I still have the problem.
Please, can someone help me?
Thx
23 Replies 23
What mtu you use with this dmvpn tunnel?
@MHM Cisco World
ip mtu 1400
ip tcp adjust-mss 1360
Ping <client tunnel IP that face issue> size 1400 df-bit source <hub tunnel IP>
Test ISP is support this mut1400 or not
MHM
@MHM Cisco World, it's down:
ping [client tunnel IP] size 1400 df-bit source [hub tunnel IP]
Sending 5, 1400-byte ICMP Echos to [client tunnel IP], timeout is 2 seconds:
Packet sent with a source address of [hub tunnel IP]
Packet sent with the DF bit set
Success rate is 0 percent (0/5)
Then check your ISP ask him about mtu size'
The router need to send packet to other routers use small mtu so it fragment it and this generate this log.
I will also check more about this log and update you
MHM
Thxs @MHM Cisco World,
After several tests, I'm getting this message from the client tunnel: %CRYPTO-4-IKMP_NO_SA: IKE message from [Public_IP_hub] has no SA and is not an initialization offer.
I'll read about this.
JonRedn11
Hi everyone,
More information for this case:
#show ip nhrp:
(remote_clientvpn_1) via (remote_clientvpn_1), Tunnel0 created 00:14:53, expire 00:05:35
Type: dynamic, Flags: nat registered used
NBMA address: (public_ip)
(remote_clientvpn_2)/32, Tunnel0 created 00:01:00, expire 00:02:04
Type: incomplete, Flags: negative
Cache hits: 7
(remote_clientvpn_3)/32, Tunnel0 created 00:02:14, expire 00:00:50
Cache hits: 7
Please, can someone help me?.  I tried a lot of test but it's doesn't work.
Best regards.
Jo
Help here' dont worry I will try to figure out what problem here.
Now I see flag NAT' this can make huge issue in dmvpn.
Are this spoke behind NAT?
MHM
JonRedn11
Hi @MHM Cisco World,
No, it's not behind nat. Look it's very weird. I realized if I reboot a client, the tunnel will up again a few minutes before falls again.
I will share some point to check if your Spoke behind NAT or not
MHM
I found new information by a debug:
*Dec 20 2023 21:06:29.268: NHRP: MACADDR: if_in INTERFACE netid-in 0 if_out Tunnel0 netid-out ID
*Dec 20 2023 21:06:29.268: NHRP: Checking for delayed event 0.0.0.0/CLIENT_VPN on list (Tunnel0).
*Dec 20 2023 21:06:29.268: NHRP: No node found.
*Dec 20 2023 21:06:29.268: IKE Dispatcher: Unexpected destination port 4500. Dropping packet!
But I don't understand exactly what's meaning of.
Did you check NAT ?
Can you share
Show ip nhrp
In hub
MHM
Yes, I did but isn't behind a nat.
In hub:
RO1Ba#Show ip nhrp
Client_VPN1/32, Tunnel0 created 00:01:10, expire 00:01:54
Cache hits: 7
Client_VPN2/32, Tunnel0 created 00:02:22, expire 00:00:42
Cache hits: 7
Client_VPN3/32, Tunnel0 created 00:01:24, expire 00:01:40
Cache hits: 7
Client_VPN4/32, Tunnel0 created 00:01:04, expire 00:02:00
Cache hits: 7
Client_VPN5/32, Tunnel0 created 00:00:07, expire 00:02:57
Cache hits: 4
I already run lab
in R1 hub
show dmvpn
it give use Spoke IP
when we return to Spoke
show ip int brief we dont see this IP
i.e. Spoke behind NAT
this can OK in some case but in other no it killed DMVPN tunnel
MHM
