Tunnel went DOWN, the fragment table has reached its maximum threshold
JonRedn11
Hi everyone,
Suddenly, my tunnels Cisco-Cisco stopped working and I'm getting those messages:
*Dec 15 2023 20:41:52.180: %DMVPN-5-NHRP_CACHE: Client 192.xxx.xx.xxx on Tunnel went DOWN.
*Dec 15 2023 20:42:10.352: %IP_VFR-4-FRAG_TABLE_OVERFLOW: GigabitEthernet0/0.102: the fragment table has reached its maximum threshold 16
*Dec 15 2023 20:42:35.201: %DMVPN-3-NHRP_ERROR: Resolution Request failed for 0.0.0.0 on Tunnel
*Dec 15 2023 20:42:41.305: %IP_VFR-4-FRAG_TABLE_OVERFLOW: GigabitEthernet0/1.300: the fragment table has reached its maximum threshold 16
*Dec 15 2023 20:43:11.329: %IP_VFR-4-FRAG_TABLE_OVERFLOW: GigabitEthernet0/0.102: the fragment table has reached its maximum threshold 16
I executed the command virtual-reassembly <max-reassemblies> according some comments but I still have the problem.
Please, can someone help me?
Thx
23 Replies 23
JonRedn11
I understand. But I have a question: Why would worked it since along time ago?
This issue of ISP' not yours.
Contact them and let them check.
MHM
In fact, I did. I'll update the case when I'll know their answers.
I wish you luck friend
Update me if you can when get answer
Have a nice weekend
MHM
Hi @MHM Cisco World
Well, the ISP told me that the problem is mine, not theirs.
I'm looking into the matter (again) and I realized the another message:
*Dec 28 2023 14:14:21.881: IKE Dispatcher: Unexpected destination port 4500. Dropping packet!
*Dec 28 2023 14:14:22.281: IKE Dispatcher: Unexpected destination port 4500. Dropping packet!
*Dec 28 2023 14:14:26.725: IKE Dispatcher: Unexpected destination port 4500. Dropping packet!
It's weird because the tunnel is UP during a certainly time and then is DOWN again.
Hi friend
can you confirm that the Hub see that the Spoke behind NAT or not ,
MHM
Hi @MHM Cisco World happy new year!
Confirm: the Hub doesn't see the Spoke behind NAT.
JonRedn11
Thank you buddy. Same to you.
Happiness!
Solution is Using MTU less than what you get from Ping (df bit set) with at least 40 bytes
*Dec 20 2023 21:06:29.268: NHRP: MACADDR: if_in INTERFACE netid-in 0 if_out Tunnel0 netid-out ID
*Dec 20 2023 21:06:29.268: NHRP: Checking for delayed event 0.0.0.0/CLIENT_VPN on list (Tunnel0).
*Dec 20 2023 21:06:29.268: NHRP: No node found.
the solution for this is run CEF in router
