02-14-2013 05:08 AM - edited 03-04-2019 07:01 PM
Hi all
I have seen on my router the following config, I see the tunnel is in transport mode, what exactly is this config doing? because all I can see in the address matches for the vpn tunnel is the endpoint of the tunnel, will this encrypt all traffic flowing these tunnels ?
its using ospf over the tunnel for routing.
crypto isakmp policy 10
encr aes 256
authentication pre-share
group 5
crypto isakmp key test address 2.2.2.0 255.255.255.0
crypto ipsec transform-set TEST esp-aes 256 esp-sha-hmac
mode transport
crypto map VPN 20 ipsec-isakmp
set peer 2.2.2.2
set security-association lifetime seconds 86400
set transform-set aes
match address vpn
interface Loopback1
ip address 1.1.1.1 255.255.255.255
interface Tunnel1
bandwidth 8000
ip address 2.2.2.1 255.255.255.0
no ip redirects
ip mtu 1400
ip flow ingress
ip ospf message-digest-key 7 md5 <removed>
qos pre-classify
tunnel source Loopback1
tunnel dest 2.2.2.2
crypto map VPN
ip access-list extended vpn
permit gre host 1.1.1.1 host 2.2.2.2
02-14-2013 05:18 AM
Transport-mode can be used if the device that generates the traffic is also the device that protects the traffic. That is the case here:
1) A packet from your internal network is routed into the tunnel because the destination is learned through OSPF.
2) The Router encapsulates the packet with GRE and adds a new tunnel-header (source 1.1.1.1, dest 2.2.2.2).
3) The outside interface will protect the GRE-packet with your crypto. No new IP-header will be inserted, the header which was added by GRE is used as the outer header.
BTW: The "crypto map VPN" is typically not needed on the tunnel-interface, only on the outgoing interface.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
02-14-2013 05:31 AM
So is this encrypting the tunnel or each packet that flows through the tunnel individually ?
how come I dont need to match all this traffic on the crypto access list and only the end ip's ?
is this actually working then ?
cheers
02-14-2013 05:47 AM
each packet that flows through the tunnel gets encrypted individually. You don't need to match the actual traffic as the crypto-map only sees the the GRE-packets from 1.1.1.1 to 2.2.2.2. These are protected with IPsec.
02-14-2013 05:56 AM
so is the config correct?
also would I need to do anything different if it was in tunnel mode? why would they have used transport mode here ?
02-14-2013 06:03 AM
That should be fine. When you issue the command "show crypto ipsec sa" you should see packets encrypted and decrypted.
You also could use tunnel-mode here but you would waste possible payload as you get an additional IP-header (one would be inserted from GRE and another one withn the same addresses from IPSec).
