02-13-2013 02:45 AM - edited 03-04-2019 07:00 PM
I have a router Cisco 2911 with two possible Wan interfaces out and a backup configuration using IP SLA. When the Primary Interface goes down the traffic is automatically rerouted through the Backup Interface, but the problem I have is that when the traffic is going through the Backup Interface (because the Primary is down) if the Backup Interface also goes down, if the Primary goes up, the traffic is not automatically rerouted to the Primary Interface. And it looks to me like it keeps trying to goes out the Backup Interface and cannot see that the Primary is down. I guess that the pings are going out the backup Interface and as it is down the router doen't receive any anwer to the ping and doesn't change to the Primary.
The main configuration related to the IP SLA is this:
track 1 ip sla 1 reachability
interface GigabitEthernet0/0
description backup Interface
ip address 175.xx.xx.10 255.255.255.252
ip nat outside
ip virtual-reassembly in
load-interval 30
duplex auto
speed auto
interface GigabitEthernet0/1
description Primary Interface
ip address 192.168.2.2 255.255.255.252
ip nat outside
load-interval 30
duplex auto
speed auto
ip nat inside source route-map backup interface GigabitEthernet0/0 overload
ip nat inside source route-map primary interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 192.168.2.1 track 1
ip route 0.0.0.0 0.0.0.0 175.xx.xx.9 254
ip sla 1
icmp-echo 62.xx.xx.5 -- default gateway in the Primary Interface
threshold 2
timeout 4000
frequency 10
ip sla schedule 1 life forever start-time now
Could you please help me to solve the problem?
02-13-2013 03:26 AM
You icmp-echo's might be going through backup interface.
ip sla 1
icmp-echo 62.xx.xx.5 source-interface g0/1
Hope it will help.
Best regards,
Abzal
02-13-2013 04:06 AM
Hello Abzal,
ip sla 1
This can indeed specify the source ip(the interface ip on G0/1), but it can't control probe traffic will go via which interface.
If you want to control the path, route-map is required, such as:
access-l 100 per icmp host 192.168.2.2 host 62.xx.xx.5
route-map INT per 10
match ip add 100
set interface G0/1 null0
ip local policy route-map INT
XIE
02-13-2013 04:15 AM
Thanks to both of us,
I will try that configuration.
Xie, regarding the route-map, when you say that "it can't control probe traffic will go via which interface" what you mean? That it won't work, or that I cannot see if it works.
02-13-2013 04:54 AM
What I meant is, you can't control how(via primary interface or backup interface) each IP SLA probe reach your tragert if only specifying the "source-interface" in IP SLA.
While route-map will simply force the ICMP traffic to the target to go via primary interface, or drop(via Null 0), this will also help to prevent default route flapping scenario.
(maybe not in your case, but help for your better understanding, flapping scenario is: primary connection down---track goes down---primary route deleted----backup route inject to FIB----IF the target in your SLA setting is reachable via backup connection----track up again----primary route inject but will keep flapping).
Hope this helps
XIE
02-13-2013 07:07 AM
Ok, I think now I understand.
So, only one more question. You both say that the source interface of the Ping must be the Backup Interface, but in the command you write g0/1 that is the Primary Interface. So, only to confirm, which Interface should be the source, the Backup one - GigabitEthernet0/0?
02-13-2013 10:39 AM
the ip sla probe should use the primary interface.
Alain
02-13-2013 10:25 PM
yes, primary
02-14-2013 08:44 AM
Ok,
I will try with that configuration.
Thanks a lot
