Turn WAN port into switchport
Codeblix
Hi all,
I have a cisco ISR-C921-4p, it have 4 lan and 2 wan port.
I want to turn set gi4 as vlan 45 and gi5 as vlan 46
config t
int gi4
switchport mode access
switchport access vlan 45
 the above command does not work, any solution?
Hello
If the rtr support sub-interfaces then you could do the follwoing:
int gi4
no shut
int gi4.45
encpsualtion dotq 45
ip address x.x.x.x
nt gi5
no shut
int gi5.46
encpsualtion dotq 46
ip address x.x.x.x
Kind Regards
Paul
balaji.bandi
I do not believe you can convert the WAN port in to switch port (As Paul suggested you can do the same config  too....)
It already has 4 switch ports you can use.
Also, follow the below guide :
https://www.cisco.com/c/en/us/td/docs/routers/access/900/software/configuration/guide/900SCG/vlanconf.html
BB
