turning on debug on 3800
Warren
Hi I was trying to run a debug for an access-list on a 3800 series router but I was unable to turn on debug for on particular access-list. I did a debug ? but it doesn't give me an option for an access-list I also did a debug ip access-list but that to doesn't allow me do a particular access-list as well. Any help on this would be greatly appreciated. By the way it is a Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9_SNA-M), Version 12.4(10a), RELEASE SOFTWARE (fc2)
Richard Burts
Warren
I am not entirely clear what you were trying to do but it sounds to me closest is that you were trying to use an access list with debug ip packet. Assuming that you have configured extended access list 190 to identify the traffic that you want to examine you would use this command: debug ip packet 190
try it and let us know if that is what you are looking for.
If that is not what you are looking for then perhaps you can clarify a bit what it is that you need.
Rick
Rick
yes that is what I was looking for but my access list doesn't have the usually numbers like it would if I was doing a normal or extended access-list. How would I do it for an access list that has a name IE:
extended IP access list vnet-in
Warren
I just tested and find that this appears to be one place where IOS does process numbered access lists but does not process named access lists. The only alternative that I see is to recode the access list as a numbered access list.
Rick
Rick
Thanks Rick I thought I was going crazy over here....thanks for your help!!!!
