Two Cisco EPC3928s in Router - Repeater mode
Hello all,
I have a bit of a problem that I hope some of you can help me fix.
I have two Cisco EPC3928s Router/Modem units. One is my primary connection from the ISP to my PC and my Wirelesses router. Also I use built in DHCP service on it. I recently got another EPC3928s and would like to use it as a WiFI repeater.
Can this be done? And if it can, how?
Best regards.
Nenad.
Hello
Looks like it possible to do - enabling WDS function on these boxes and setting the base mac address of the additional  3928 in the WDS settings of the primary 3928  <page 51 of this document>
Kind Regards
Paul
So it should find it over WiFi and connect to it? Even set the same SSID?
I will post results after I try this out.
