Two IPV6 prefixes have same meaning under prefix-set in ASR9K?
wfqk
Level 5
Level 5
Do you think the below two prefixes are different under prefix-set ABCD
1111:2222:3333:4444:5555:6666:7777:8888
1111:2222:3333:4444:5555:6666:7777:8888/128
I think these two expressions have different meaning. Second one indicates its mask 128, but first one does not. Can we consider the first one’s mask is also 128 by default? If so, when the two routes are put under prefix-set in ASR9K, the two prefixes have the same meaning?
Please see the below two:
prefix-set ABCD
and
prefix-set ABCD
thank you
blau grana
Level 7
Level 7
documentation is always your friend :)
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r6-1/routing/configuration/guide/b-routing-cg-asr9k-61x/b-routing-cg-asr9k-61x_chapter_01011.html#con_1228824
"If a prefix match specification has no mask length, then the default mask length is 32 for IPv4 and 128 for IPv6."
XR will allow you to configure lot of combinations but per documentation it will always match same prefix
RP/0/0/CPU0:ios#sh run | begin prefix
Building configuration...
prefix-set ABC
  1111:2222:3333:4444:5555:6666:7777:8888/128,
end-set
prefix-set TEST
end-set
prefix-set TEST-1
end-set
prefix-set TEST-2
  1111:2222:3333:4444:5555:6666:7777:8888,
end-set
end
Best Regards Please rate all helpful posts and close solved questions
blau grana
Level 7
Level 7
prefix-set ABC
end-set
prefix-set TEST
end-set
prefix-set TEST-1
end-set
prefix-set TEST-2
end-set
end
Thank you!
