Two ISP DSL connections, Nat, Routing based on source address
mueller
we have a 1812 connected to two ISPs with PPPoE.
dialer0 has static IPs, dialer1 has IP negotiated.
Inside we have
vlan1: 10.0.10.0/24
vlan2: 10.0.11.0/24
vlan3: 10.0.0.0/24
At the moment 10.0.11.10 has static nat:
ip nat inside source static 10.0.11.10 79.140.54.10
and all other internal IPs are dynamic nat:
access-list 105 deny ip 10.0.10.0 0.0.0.255 10.0.250.0 0.0.1.255
access-list 105 deny ip 10.0.0.0 0.0.0.255 10.0.250.0 0.0.1.255
access-list 105 deny ip 10.0.11.0 0.0.0.255 10.0.250.0 0.0.1.255
access-list 105 permit ip 10.0.10.0 0.0.0.255 any
access-list 105 permit ip 10.0.11.0 0.0.0.255 any
access-list 105 permit ip 10.0.0.0 0.0.0.255 any
ip nat inside source list 105 interface Dialer0 overload
Now I want:
vlan1 -> dynamic nat dialer0
vlan2 -> dynamic nat dialer0
vlan3 -> dynamic nat dialer1
I've tried to set an access-list and
ip nat inside source list 106 interface Dialer1 overload
for the vlan3 IP's. The packets where nat'ed correctly, but sent out on dialer0. So the incoming replys on dialer1 are dropped by access-list cause the "ip inspect bla out" on dialer1 did not know the packets.
So how can I route packets from vlan3 after nat through dialer1?
thanks
carsten
paolo bevilacqua
you need policy routing for that:
route-map to-isp
match ip address 106
set interface dialer1
interface vlan3
ip policy route-map to-isp
paolo bevilacqua
route-map to-isp
interface vlan3
