Two ISP links at different locations and want to Load balance
thomuff
Level 3
Level 3
My company has two ISP located at two different locations. They want to load balance between the two sites. At another company, we connected the two internet switches via a pair of fiber so we could failover. I do not have the fiber option in this situation so am I out of luck or is there another way. I would run BGP on the two internet routers. and I am thinking about GLBP on the two routers.Thanks
when you say you want to load balance between two ISPs at two different locations, do you mean that your company has two sites that each have a connection to an ISP ?
You might want to check this document for the BGP part, it has congfiguration examples for various single- and multihomed scenarios:
Load Sharing with BGP in Single and Multihomed Environments: Sample Configurations
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00800945bf.shtml
GP
Yes That is correct. For example.
Location A is connected to ISP X
Location B is connected to ISP Z
Location A connect to Location B via T1
Location A is the Primary with ISP X
Location B ISP connection is not used at all right now. It is up just in case of Location A burning down or getting flooded, or worse.
Another method, I am thinking is point half the sites to Location B as the primary but that would take circuit reengineering, duplicate hardware etc.. A duplicate location. That document is very informative. Thank you.
mohamed-khadr
Why do u want to go the BGP route when a simple static route config can do it and save u a lot of headache.If u like to do it that way, I can give some config.
mohAmed khAdr
Yes, I would like to do it that way. It doesn't look like I can do it with BGP anyway.
Tom
