Router selection
Djones11
I need assistance in selecting a router that has the following interfaces.
Qty (6) Ethernet all 10Base-T
(2) LAN connections
(2) Internet Connections
(1) to WI-FI (802.11B) reciever
(1) to Satellite Terminal
Qty (1) Analog for Voice
Qty (1) T1-PRI for PBX (Voice/Fax)
I was looking at the 2811 with NM-HDV2-1T1 and VIC2-2FXS to support the T1-PRI and voice. The problem is the ethernet links. I dont believe the 2811 will support my Ethernet links. Can anyone point me in the right direction?
DJ
nathan.deane
You could use the following for the Eth Interfaces
HWIC-4ESW USD
$425.00
Four port 10/100 Ethernet switch interface card
Why so many Eth ports needed ?
Nathan
7 Replies 7
nathan.deane
HWIC-4ESW USD
$425.00
Nathan
This is going on an oil platform and i need to support ethernet via 802.11B (wi-fi)in one direction to another platform and Ether to Satellite for shore. not to mention the 4 ethernet for rig lan and internet pc support. I was not aware that the 2811 had HWIC-4ESW.
Thanks for your help
DJ
DJ,
Have you looked at the 1801W routers. These have a builtin 802.11a/b/g support plus an uplink port which is mostly DSL interface. Very good for SOHO's.
Sankar.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thanks, Sankar
But i'm being handed 4 distinct 10/100 copper links to support my LAN segmentation. and i'm not sure now if the 2800 with HWIC-4ESW will work. HWIC are for Layer 2 switching to end devices. I need Layer 3 for routing right. I'm not a Network Subject matter expert. Do you know what i can use (router wise)to support 4 LAN's, 2 airial links (1 Wi-Fi, and 1 Satellite), and 1 T1-PRI (23 Ch) and 1 Fax line?
I know the NM-HDV2-1T1/E1 with the supporting VIC2-2FXS will support my voice w/PVDM2-32 for Voice compression. But i need it all in a single unit.
DJ
arvenugopal
hi
you can use the cisco 2811 as the router which supports all the requirements.
http://www.cisco.com/en/US/products/ps5949/products_data_sheet0900aecd8028cc7b.html
4 port ethernet
http://www.cisco.com/en/US/products/ps5949/products_data_sheet0900aecd8016bf0b.html
2 Port FXS
and
2 port multiflex module
http://www.cisco.com/en/US/products/hw/modules/ps3115/products_data_sheet09186a0080091b9c.html
I hope this URL will clarify all your purpose
Isn't this hwic-4esw a 4 port routed interface like the nm-4e . I don't think it is, so does it meet the requirements by the topic starter ?
The Cisco 10/100BASE-T Ethernet switch HWIC provides Layer 2 switching for traffic between one port on the HWIC and any other port on the same HWIC. The HWIC also supports Layer 3 traffic to and from the HWIC and any of the other platform interfaces. Traffic between different VLANs on the switch is routed through the router platform.
Two Cisco 10/100BASE-T Ethernet switch HWICs can be stacked in a router chassis to provide expanded switching capability. See the "Stacking of Cisco 10/100BASE-T Ethernet Switch HWICs" section for a detailed description.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/cis2600/hw_inst/wic_inst/wic_doc/esw_hwic.htm#wp1037901
Dont i need Layer 3 Routing for my four (4) seperate LAN's? Not to mention the Satellite and Wi-Fi links.
I know it needs to be modular to support my voice connections with VIC and DSP for compression, so will a 3800 work for my requirments?
DJ
