Two ISP´s and two LAN´s on the same router ?? help !!!
mcelec
Hi people,
I have a 1721 router with two wic-1t interfaces, and, in my F0 interface, I have the primary and a secondary ip addresses, I need LAN1 is diferent to LAN2,(IP addresses)
In other words LAN1 goes to one wic-1t to ISP1 to Internet and LAN2 goes to another wic-1t to ISP2 to Internet.
My problem is I do not know what kind of ip route I need in order to send my two LAN´s to Internet with my two wic interfaces, maybe a load balancing or something like that.
In Fact I do not know if that is posible.
Can somebody helps me?, has somebody a nice link about?.
Thanks a lot who can or wants give me a hand.
MC
5 Replies 5
antonyjaison
Hi MC,
Its possible thruogh policy based routing . Below i am pasting sample configuration for you.
access-list 101 permit ip "LAN 1 Address and Mask" any
access-list 102 permit ip "LAN 2 Address and Mask any
route-map isp permit 10
match ip address 101
set ip next-hop "ISP-1 Next hop address"
route-map isp permit 20
match ip address 102
set ip next-hop "ISP-2 Next hop address"
interface FastEthernet 0
ip policy route-map isp
Add the LAN 1, LAN 2 and next hope addresses based on your setup.
Jaison
When you route packets to two ISPs, you also need to worry about what ip address space you are going to nat your private network to. You will have to use NAT with route-maps to achieve this.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thank you very much for your answers gays,
I can not do any test today due Internet here is very important,
but now I have a new doubt,
I have a tipical NAT configuration (with its ip nat inside and outside and making NAT to s0 interface with a ACL of internal LAN.
My current NAT configuration is changed ??
Thanks for your comments
It was totally uncalled for to out them like that after they helped you out! :) LOL!!! Remember, Don't ask, don't tell!!!
Its not required you to change your current NAT configurations.
Jaison
